Old 03-09-2021, 07:16 PM
jt4242 jt4242 is offline
IMDB read failed
I just started having problems looking things up in IMDB. I get the list of titles but when I try to open one, I get the following error:
IMDB read failed:
reading Title:All Rise(2019) (TV Series)
net.sf.sageplugins.sageimdb.DbFailureException: Failed to find content in Title reference Page https://www.imdb.com/title/tt10183798/reference
at: net.sf.sageplugins.sageimdb.ImdbWebGetTitle.get:492
Is anyone else having problems?
Old 03-09-2021, 09:26 PM
I can confirm that I am getting the same error
Old 03-10-2021, 07:40 AM
Tiki's Avatar
Tiki Tiki is offline
+1, I noticed it stopped working yesterday.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 03-10-2021, 08:47 AM
I wonder if it is a temporary hiccup? I use it all the time to fill in missing metadata and just to satisfy my curiosity during a show when I see someone and know I've seen them before but can't remember when and in what - so handy!
I've PMed JREkiwi who fixed the plugin in 2019 to see if he can suss out what has gone wrong but I don't know if he is still active.
Old 03-10-2021, 04:45 PM
+1 here as well. As Tiki mentioned, it stopped working yesterday.
I use it quite often as well. "where have I seen that actor/actress before?" Is usually my reason for the query.
Wayne Dunham
Old 03-10-2021, 04:56 PM
exactly! I'd really miss having that.
Old 03-11-2021, 01:35 PM
I'd suspect that IMDB changed something in either the way information is requested, or how or the content of what is delivered causing the plugin to fail. That has happened multiple times in the past, but back then all the plugin developers were still around and quick to fix the issue.
Sadly I think we're circling ever closer to the drain.
Wayne Dunham
Old 03-11-2021, 09:55 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
Not sure if I could every be described as active
I'll have a look over the weekend
John
Old 03-12-2021, 12:34 AM
JREkiwi's Avatar
A quick mod to get it back to it's previous broken state (No Backstage Info)
Unzip this file
Shut down SageTV and replace the JARS\nielm_sageimdb.jar with this one
John
Old 03-12-2021, 06:08 AM
Unzip this file
John
It works!!! Thank you SO much.
Old 03-12-2021, 12:15 PM
Downloaded the file and heading over to the SageServer machine to install it.
Thanks so much for fixing this!!
Now, who do we message to get the web and mobile web interface fixed to work with Java 8? Some features are broken under Java 8. Yeah, I know, give them and inch....
Wayne Dunham
Old 03-12-2021, 01:17 PM
egeller egeller is offline
A note on the JAR file. Don't forget to install it on Windows Clients as well as the server, if you have both.
Web interface has a pretty easy workaround. I do not use the mobile, but maybe someone can figure it out based on what I have here.
To get the Web Interface running, easily, with Java 8:
  • Create folder ../sagetv/server/jetty/static/
  • In that folder, populate it with, at least, 1 file, named index.html. In its simplest form, it only needs to contain the links you want to access.
  • Access your server with the URL http://yourserver_name_or_ip:8080/. Jetty defaults to the web page named index.html.
A sample index.html is attached. Link references are relative, not absolute, so it won't work until it's installed.
Feel free to correct / change it. You can make it whatever you want and add links to it. The attached version is edited and mine contains a dozen or so links to various things I have on my network.
File Type: zip index.zip (552 Bytes, 39 views)
SageTV Extender:3x HD200 1x HD300
Sage TV: 9.2.1, Standard STVi, Comskip Playback, Web Interface, 24 Hour Clock, SRE, YouTube2015, Playon
All in lovely Drexel Hill, PA
Old 03-12-2021, 06:12 PM
JREkiwi's Avatar
I've added the latest file which also fixes the backstage issue to the V9 repository so should prompt for a CMT update that will also update this JAR. The V7 repository no longer allows submissions, so I've added the latest JAR here if for some obscure reason anyone is still running V7. (Upgrade to V9 )
Manual process for V7
Unzip this file
Shut down SageTV and replace the JARS\nielm_sageimdb.jar with this one.
If you are running SageTV Clients, you will also need to replace this file on them too.
John
Old 03-13-2021, 07:32 PM
How long does it usually take the plugin manager to prompt for an update?
Old 03-13-2021, 07:51 PM
JREkiwi's Avatar
It's usually within a day, but it still hasn't been merged. It's a automated process and I'm not even sure who's looking after it now.
John
Old 03-13-2021, 08:59 PM
I'm too impatient so I just manually replaced the JAR instead. Works great again!
Apart from Comskip, I think I use this plugin more than any other SageTV plugin.
Thanks for keeping it working for us
Old 03-14-2021, 01:47 AM
elcid elcid is offline
Unzip this file
John
Hi.
Where is this file?
Old 03-14-2021, 07:06 AM
jusjoken jusjoken is offline
John
It seems nobody is looking after it now but I saw the request and merged it. We may need a volunteer to do these merges in the future
Old 03-14-2021, 06:44 PM
John
As of Sunday 3/14 late afternoon at least the updates are in the repository and show as updates for the related plugins. At least that's when they showed up in my "Setup/System Messages" area of the main menu.
Wayne Dunham
Old 03-14-2021, 07:06 PM
Getting access to the original webserver and mobile webserver aren't really the issue for me. I have the links for them saved in my bookmarks. I can access them locally or on the road using my DynDNS connection.
I don't want to hijack this thread, but wanted to say that at least for me the old webserver works for searching the EPG, but doesn't work 100% when searching Recordings since going to Java 8. The newer mobile webserver tosses up an Error message "Error
Message: PWC6033: Unable to compile class for JSP PWC6199: Generated servlet error: The import java.util.Arrays cannot be resolved PWC6197:
An error occurred at line: 14 in the jsp file: /WEB-INF/tags/sage/functions/collections/ArrayToList.tag PWC6199: Generated servlet error: Arrays
cannot be resolved"
It throws up that same error message whether trying to Searh EPG or Search Recordings. This only happened after moving to Java 8.
Odd that the Search EPG works fine in the much older original webserver, but not in the newer Mobile Webserver.
In the original Webserver searching recordings gets some mixed results. It hs trouble finding current recordings, but seems to see past and future airings just fine.
Wayne Dunham
Automatic Metadata Failed (Code 10100) IMDB: Failed to parse providerDataUrl: mkanet Batch Metadata Tools 2 10-12-2010 03:22 PM
BMT: Read this if you don't see any BMT topics Opus4 SageTV Customizations 0 04-25-2010 09:17 PM
Failed IMDB search spook SageMC Custom Interface 12 12-04-2008 02:51 PM
forum posts not marked read when read? xlr8shun The SageTV Community 2 05-04-2004 01:49 AM
