Old 04-20-2019, 11:27 PM
LHuisingh LHuisingh is offline
Display issues with 9.2.1 on HD300
I just installed the 9.2.1 update. I've noticed that on my HD300 unit the text on some of the menus is getting cut off at the top of the text. See the attached screenshots. I did not see this in 9.1.5. Any ideas?
Old 04-20-2019, 11:34 PM
wnjj wnjj is offline
Are on on the 32-bit version? See this post: https://forums.sagetv.com/forums/showthread.php?t=65929
Old 04-20-2019, 11:48 PM
Yes, I am using the 32-bit version. If I understand from the referenced thread, the solution provided would affect the computer running the software. Would that affect the HD300? I don't have the problem on the server itself. it's just on the HD300.
Old 04-21-2019, 12:16 AM
The rendering for the HD300 is done on the server so it can affect it. You can either install the old DLL or try deleting the contents of the fontcache directory if you’re not using the Android miniclient.
Old 04-21-2019, 09:46 AM
Thank you! Deleting the contents of the fontcache folder while the service was off worked great! Thank you!
Did I say "Thank you?"
font, hd300, text
HD300 Display Corruption via Yamaha Amp sota SageTV Media Extender 3 06-06-2014 04:01 AM
LZ display issues [JiF]Mike Phoenix 2 09-05-2011 12:12 PM
Poster display issues in epg Gustovier Phoenix 3 07-10-2011 08:29 AM
HD300 Powers but no display on tv Bone SageTV Media Extender 8 04-04-2011 03:19 PM
Tip: Calibrate Display Using HD300 peternm22 SageTV Media Extender 0 09-27-2010 12:08 AM
