Old 04-03-2008, 02:16 AM
cactusbob cactusbob is offline
Editing frequency files
I wonder if anyone can help? I'm in the UK and I'm trying to get my channel lineup the way I want (I have about 200 channels via satellite). I have a .frq file named after my receiver card exactly the same as how it was when I scanned for channels within Sage:
FireDTV BDA Receiver DVBS2-0-DVB-S.frq
My channels are sorted and set out like this:
CH:101 onid:2 tsid:2050 sid:6903 frq:10847000 rate:22000 mod:20 pol:2 fec_rate_in:6 sat:0 ctrl:1 #:BBC-1-East-(W)
CH:102 onid:2 tsid:2045 sid:6302 frq:10773000 rate:22000 pol:1 fec_rate_in:6 sat:0 ctrl:1 #:BBC-2-England
CH:103 onid:2 tsid:2041 sid:10181 frq:10714250 rate:22000 mod:20 pol:1 fec_rate_in:6 sat:0 ctrl:1 #:ITV1-Anglia-W
CH:104 onid:2 tsid:2024 sid:9201 frq:12168000 rate:27500 mod:20 pol:2 fec_rate_in:2 sat:0 ctrl:1 #:Channel-4
CH:105 onid:2 tsid:2057 sid:7700 frq:10964250 rate:22000 mod:20 pol:1 fec_rate_in:6 sat:0 ctrl:1 #:Five
CH:106 onid:2 tsid:2027 sid:4705 frq:12226500 rate:27500 mod:20 pol:1 fec_rate_in:2 sat:0 ctrl:1 #:Sky-One
CH:107 onid:2 tsid:2027 sid:5104 frq:12226500 rate:27500 mod:20 pol:1 fec_rate_in:2 sat:0 ctrl:1 #:Sky-Two
I'm going to use XMLTV data to mapguide data to these channels. The problem I have is that my revised channel list isn't showing up in Sage. Are the channels stored somewhere else or am I missing something glaringly obvious?
Old 04-03-2008, 05:20 AM
krikkit's Avatar
krikkit krikkit is offline
the .frq file does not define which channels you get in sage tv... the channel lineup you see is stored in sage.properties and wiz.bin i think...
but to solve your problem: in sage under channel setup, just use the "remap to different physical channel" feature
e.g: you have "BBC World" in your channel list, look up in your .frq file which channel number it has, remap in sage to this number...
WWW: http://www.krikkit.net
Server: Athlon X2 4850e (2x2,5Ghz); AMD 780G Chipset, 2 Gb RAM ; ATI Radeon HD 3200; Technotrend S2-3200 DVB-S + CI, Hauppauge PVR 150 (only as IR receiver)
Winows XP Pro; SageTV v6.4.5
Clients: Placeshifter
Old 04-03-2008, 05:58 AM
Thanks for the reply, I think it has something to do with the overrides property in the config file. I shall have a play
SageTV FAQ Narflex SageTV Software 45 04-15-2011 08:34 AM
Search for non-converted files, or specific file types ben_gb SageTV Software 2 09-28-2007 06:40 AM
what I don't understand: TS files and network encoders potpiejimmy Hardware Support 4 01-10-2006 02:28 PM
