Go Back   SageTV Community > SageTV Products > SageTV Recorder Software
SageTV Recorder Software Discussion related to the SageTV Recorder application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Recorder should be posted here.
Old 06-29-2004, 01:08 PM
dkardatzke's Avatar
dkardatzke dkardatzke is offline
SageTV Co-Founder
SageTV Recorder 1.5.6 Maintenance Release
There is a new maintenance release available for Version 1.5 of SageTV Recorder. The release is version 1.5.6 and the following items have been fixed:
1. Fixed issue where using multiple Roslyn cards on some motherboards didn't work.
2. Fixed issue where the ATI eHome Wonder cards weren't supported correctly.
You only need to upgrade if you have experienced any of the above issues. There is no new functionality in this release. The new version is available at www.sage.tv/download.html.
To upgrade just install the new version over any older version of SageTV Recorder. Any support questions, should be directed via support request at www.sage.tv/request.html or use the forums for support from other customers.
Dan
Dan Kardatzke, Co-Founder
SageTV, LLC
Old 07-29-2004, 01:49 PM
Malc C Malc C is offline
Dan,
Any chance of supporting the Adaptec AVC 2010 cards now used in their PCI versions of the Videoh! product
Old 09-01-2004, 11:36 PM
newtbert newtbert is offline
When I access Setup/About, SageRecorder still says its version V1.5.5
Is that normal or should it say 1.5.6?
Old 09-24-2004, 11:55 PM
phenixdragon phenixdragon is offline
So is the ATI eHome Wonder supported 100% at this point? And does that include having a PVR 250 card in the mix?
Old 01-24-2005, 02:04 AM
lbc lbc is offline
Will Sage Recorder support pvr-150 cards anytime soon?
Old 01-24-2005, 08:00 AM
JUC's Avatar
JUC JUC is offline
I think they might be moving away from sagerecorder. I believe it is now possible (although not yet supported) to use a second instance of sagetv as a networked encoder--thus utilizing all the supported cards available to sagetv.
JUC
Old 01-25-2005, 08:19 PM
that_kid that_kid is offline
JUC
Do you know how one might go about doing this. I see the option in sage.properties but what else would one need to do to get this working. This would be great for me as I have only pvr 150 cards and I've run out of slots in my server so putting a card or two on the client side would be great.
Old 01-25-2005, 09:32 PM
This is what Frey support has sent out for people to try:
Try this. The directions are similar to setting up network encoders with SageTV Recorder. Except most lines that refer to SageRecorder will actually refer to SageTV that will act as the network encoder.
Install SageTV on that machine and look for this line in the properties file, "enable_encoding_server=false" and set it to true. This is similar to line 2 of the text file I attached. Now run SageTV and setup the card and configure it to work properly. Close it down. Continue with the network encoder directions as outlined.
For step 14 do this. Go back to the machine that will run the network encoder and run Sage. Delete the source you added in the Setup Wizard. This is how it will stay. Now just minimize and leave it there. When you run the SageTV server it should be configured already, if not then just add the source.
(ALSO IF YOU WANT TO RUN MULTIPLE ENCODERS, JUST ADD THE PORTS IN THE PROPERTIES FILE. SEPARATED BY A COMMA)
The instructions for using SageTVRecorder as a network encoder are here: Setting up Network Encoders
Note that after configuring the tuners, I believe you need to use the "-client" command line parameter (without the quotes, of course) for the network encoder copy of SageTV in order for it to act as a client.
Old 01-25-2005, 10:57 PM
Thanks I'll give this a try.
Old 01-26-2005, 06:47 AM
SidKnee SidKnee is offline
Does anyone know how this works with licensing?
Will the instance of SageTV that you want to use as a network encoder accept an original Sage Recorder licence, or will it only accept a full SageTV licence?
Cheers,
SidKnee
Old 01-26-2005, 08:09 AM
JUC's Avatar
JUC JUC is offline
I believe the second instance of SageTV will require a seperate ful license, and not work with a recorder license. The downsides of this is that the full sagetv app costs more than the recorder and client, BUT--you can save by using the PVR150's which are not supported by sagerecorder.
JUC
Old 01-26-2005, 10:04 PM
Yeah that's true but for me it works out because I can add more cards to my system that 1 server couldn't do(not without expensive magma expansion equipment). I'm thinking that I can do on the second recorder what I'm doing on the first which is use the sage server ui to run my second mvp and just run sage client on that same machine. It's nice to have all these options, I don't mind getting another server license.
Old 01-27-2005, 04:45 AM
I guess that some will win and some will lose with this then. Personally it means that I'll either have to move some cards around, or pay for an additional license.
It doesn't really matter at the moment as Sage doesn't look to be working well with the 150 (PAL) cards anyway so I can't do a thing
Thanks for the info!
Cheers,
SidKnee
Old 04-15-2005, 03:01 PM
davey_fl davey_fl is offline
can you use a client instance of sage as a network encoder? Or just recorder/sagetv??
thx
david
Old 04-15-2005, 03:58 PM
SageTVClient cannot directly control a tuner. So, you would have to use either SageTV or SageTVRecorder to set up a network encoder.
Old 05-31-2005, 07:11 AM
So does anyone have this working with PVR-500s? I tried it last night but I get constant lockups when it attempts to use a network encoder, requiring a CRTL-ALT-DEL shutdown of Sage...
Old 01-06-2006, 11:09 PM
Homebuilder Homebuilder is offline
full sage working as client recorder
Hi, I am trying to set up a client as a firewire recorder. I bought a full license and have set it up as you mentioned. Just two questions I was hoping you could help me with.
First, does it work with version 4.14?
Second, when you say command line "-client" What do you mean? How do you do that?
Thanks in advance!
Old 01-06-2006, 11:44 PM
Never mind, figured it out... create a short cut to sagetv.exe. Add -client in target area of properties of said shortcut. Works!
Old 04-14-2006, 06:10 PM
sjc999 sjc999 is offline
Question Network Encoder and Client.
I just came across this and am interested in the ability to use SageTV itself as a network encoder instead of Sage Recorder. My question here is will a single copy of SageTV act as both a client and a network encoder at the same time? Also, for that matter, is it supported to run Sage Recorder and Sage Client on the same machine?
Thanks for any light anybody can shed.
Steve
Old 04-14-2006, 06:53 PM
Yes, as mentioned in a post somewhere above, use the -client parameter with a 2nd instance of sagetv.exe.
BTW: this post has the latest info regarding using SageTV as a network encoder.
yes.
