Old 08-13-2015, 01:33 PM
Rebuild Sage.jar (Windows and Linux and probably Mac)
See the BUILDING file for details on rebuilding the Sage.jar and setting up Eclipse and/or IntelliJ build projects.
The goal would be to extend the cross platform gradle builds, but for now, rebuilding the Sage.jar is just just 2 steps
1. Clone the repo
2. run gradlew.bat sageJar
I think it goes without saying that you also need to have a JDK (not JRE) installed as well.
Old 08-13-2015, 03:06 PM
tmiranda's Avatar
tmiranda tmiranda is offline
Brilliant. I suspect 99% of development will be done in Sage.jar.
Old 08-13-2015, 06:26 PM
I've noticed, that for peak usability, we need to rebuild the exe's as well. At least in the client exe, it still asks for license keys. They are not required, and you can hit esc 4 times to get by it, but it does appear to need that check removed and recompiled. I have yet to attempt compiling it, as I've got to somehow find a copy of vs 2005.
Old 08-13-2015, 06:36 PM
Forgive my ignorance, since it's been about 20 years since I've developed on Windows... but isn't Visual Studio a free download?
https://www.visualstudio.com/en-us/p...xpress-vs.aspx
Old 08-13-2015, 06:41 PM
Will the express version of VS 2005 work? I found links to the microsoft ISOs here: http://apdubey.blogspot.com/2009/04/...5-express.html
Old 08-13-2015, 07:02 PM
probably.
Old 08-14-2015, 05:22 AM
Damstas Damstas is offline
Hi. Should I wait for an installer for Windows? I have no coding skills :P
Old 08-14-2015, 05:31 AM
Probably... it's going to take some time to get everything in order.
Old 08-14-2015, 06:12 AM
Ok. Thanks.
Old 08-14-2015, 06:22 AM
1) There's really no benefit to V9 yet, it's (from a user perspective) Functionally identical to V7.
1a) Unless you want the YouTube plugin with progressive downloading.
2) You can just install V7 and then swap out the sage jar file.
Old 08-14-2015, 07:27 AM
rickw rickw is offline
Eclipse is still a mystery to me, but the gradlew worked like a champ. I'm now the proud owner of a shiny new Sage.jar.
Rick...
Old 08-14-2015, 07:37 AM
harrijay harrijay is offline
Don't actually need Visual studio to build the solution. the commands can be sent to msbuild, which comes installed with .net by default. I will take a look at modifying the files and coming up with the command line to build without VS.
Jayson
ESXi Host Intel Xeon x3440 on Intel S3420PLX, 4GB RAM, 80GB Primary
Server:2 CPU's and 2GB memory Allocated, 15GB Virtual Primary, 1.5 TB RDM Physical Disk,
A180 using VMDirectPath, 1 xHDHR
Headless ArchLinux 2.6.34 64-bit, SageTV 7.0.15
Sun JRE 1.6.0_20
Comskip&PlayonWindows XP 2CPU and 1GB Ram Allocated
Clients: 1 Media MVP and 2 STX-HD100
Old 08-14-2015, 07:56 AM
Would it be better if I upgraded the projects and solutions to a new version of Visual studio? I have all versions at my disposal at work :-) 2003-2013
@Narflex
There are some projects that are missing in the SageWorspace solution, EVRPresenter, MPEG2Dump, MpegAudioEncLayer2, MpegMux, and MusicVisFilter, I am assuming this was intentional, and can be removed from the solution, but just wanted to make sure.
Jayson
Sun JRE 1.6.0_20
Old 08-14-2015, 07:58 AM
I would think EVRPresenter would be important since V7 could render to EVR.
routerunner's Avatar
Jayson
You're right, you don't need Visual Studio to build the solution, but you need the MS C/C++ compiler that comes with VS in order to build the DirectShow filters for instance.
Eddy
Old 08-14-2015, 08:04 AM
I'll vote MSVC2010 as this is the version I'm using to build the DVBDCC.ax filter
Eddy
Old 08-14-2015, 08:05 AM
moothekow moothekow is offline
@Narflex
Jayson
My vote is for VS2012 -- http://www.microsoft.com/en-US/downl....aspx?id=34673
I have a normally licensed version of 2012 - but seems like the express edition would work for these purposes?
Old 08-14-2015, 08:49 AM
@Narflex
Jayson
In reality, I'm thinking since all the launcher really does is that, launch the jvm, that it might not be that difficult to essentially write a replacement in .net, or any other more modern language. Would likely be far more maintainable.
Old 08-14-2015, 08:52 AM
Taddeusz Taddeusz is offline
The community editions are pretty full featured. I think they include pretty much everything except maybe features that are available in the Ultimate releases.
I think it's interesting that Microsoft has now made the Windows development tools free. I think it shows a change in mindset that getting software built for Windows is a larger priority than selling the tools. The tools are just a means to an end rather than a means unto themselves.
Old 08-14-2015, 08:54 AM
I think the major differences between the community and commercial editions is in the license to sell the work.
Any threads out there on how best to rebuild your sage server??? MickBurke SageTV Software 5 06-07-2015 08:11 PM
database rebuild on sage startup comet48 SageTV Software 4 03-16-2011 06:12 PM
Transition from Windows to Linux Sage Server tsheal SageTV Linux 21 11-09-2010 06:57 AM
How do I rebuild sage from scratch rdefino SageTV Software 3 11-15-2008 04:27 PM
Will this method work to rebuild my Sage box? Fountainhead SageTV Software 6 05-23-2007 11:16 AM
