Old 10-27-2015, 12:30 PM
sacrament055 sacrament055 is offline
HD300 Motion Adaptive De-interlacing
Just wanted to note that if others are having this problem it may help them as well. My Samsung TV kept showing odd slow motion (possibly dropped frames) during sporting events mainly large camera moves with lots of moving parts. After much investigation and turning things off and on in the TV menu I finally stumbled upon the answer. In my case at least, turning off "Motion Adaptive De-Interlacing" on the HD300 fixed the problem.
Old 10-28-2015, 10:10 AM
will will is offline
I'm having a similar issue; where do you find t his option in the HD300?
I looked in all the setting menus and didn't find any mention in the help file either.
Will
OS: Windows 7
Old 10-28-2015, 11:26 AM
Did you look in the stand alone settings on the HD300? I've seen it before I just don't remember if it was connect to a SageTV server or if it was in the stand alone settings.
Old 10-28-2015, 11:45 AM
HelenWeathers's Avatar
in the client properties file there is this:
advanced_deinterlacing=true
Old 10-28-2015, 03:21 PM
In my case I changed the settings via Setup->Detailed Setup
I'm not at home at the moment so I don't remember exactly which submenu it was in but it is available to change via the GUI.
Old 10-28-2015, 03:39 PM
At home now so:
Setup>Detailed Setup>Multimedia > Last item on Right after scrolling down = "Motion Adaptive Deinterlacing"
From default STV no Gemstone or other GUI.
Old 10-29-2015, 12:18 PM
Originally Posted by BobPhoenix View Post
At home now so:
Very odd; I don't have that option.
I'll have to adjust it in the client properties file.
Will
OS: Windows 7
Old 10-29-2015, 12:20 PM
AH now I understand. I thought you were looking for it on an extender. It probably isn't a feature that is available for a client just the extenders. I don't remember it being on a HD200 either but I could be wrong about that.
Old 10-29-2015, 12:39 PM
Yeah, it won't be on there on Client, that's only there for extenders, and I think only the HD300. Deinterlacing settings for Client would be in the properties/settings (outside Sage) for whatever decoders you're using.
Old 10-30-2015, 05:56 AM
I meant the client properties file on the server for the extender.
I was looking on a HD200. It never dawned on me that this would be a HD300 only feature (and it is there on the HD300 - I just checked). I tend to forget that there are differences between the HD200 and HD300 besides native DTS decoding.
Sorry for the mix-up.
Will
OS: Windows 7
Old 11-02-2015, 01:20 PM
The setting is also available in the stand-alone settings on the HD300. I found them over the weekend. I believe the path is Settings > Advanced Settings - last item in list on right side.
Old 11-06-2015, 11:00 AM
drewg drewg is offline
Perhaps a dumb question, but wouldn't enabling native output resolution switching also fix the problem, since the HD300 would send a 1080i signal to the TV?
I just got a 4K Samsung, and have re-enabled native output switching so that 720P gets upscaled just once, not twice.
Drew
Server HW: AMD Ryzen Threadripper 2990WX 32-Core
Server SW: FreeBSD-current, ZFS, linux-oracle-jdk1.8.0, sagetv-server_9.2.2_amd64
Tuner HW: HDHR
Client: Nvidia Shield (HD300, HD100 in storage)
HD300 Audio Dropout Issues through HDMI & Motion Adaptive Deinterlacing Crazyivan SageTV Media Extender 2 04-15-2011 06:04 PM
Smooth fast forward, rewind, and slow motion on HD300? timg11 SageTV Media Extender 7 01-11-2011 07:30 PM
HD300: Motion Problems [RESOLVED w/ beta firmware] broconne SageTV Media Extender 9 09-22-2010 02:45 PM
Missing "Pixel Adaptive" (6200 Series) HELP! jsidlosky Hardware Support 10 09-26-2005 02:58 PM
Catalyst 5.6 enables pixel adaptive deinterlacing with ATI cards something fishy Hardware Support 1 07-01-2005 06:14 PM
