Old 07-12-2019, 08:42 AM
nyplayer nyplayer is online now
CMT not creating Properties files ....
It appears that CMT is failing ... using latest Windows release... Not Creating Properties files.
Edit Appears to be working after reinstall.
Old 07-12-2019, 02:10 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
There are a few qualifications about when the CMT .properties files are created/updated.
.properties files are created automatically by SageTV whenever metadata is changed and contain only the changed metadata. CMT does a dump of the full metadata into the .properties file.
BMT by default will not scan a media file if it has an existing .properties file, so CMT will does not process the file until BMT has flagged the file as having been scanned.
BMT is reliant on the video library scan period, so it does mean the properties file may not be created until some time > the video library scan period.
The log is showing that it is looking for eligible files.
Hope that clears it up?
John
Old 07-16-2019, 07:52 PM
John
Yes it does thank you.
Help with creating a playlist from Temp Media Files PLUCKYHD SageTV Studio 13 07-09-2010 11:27 AM
debug logging not creating txt files orrd SageTV Software 2 10-08-2009 04:09 PM
stopping HD-PVR from creating files tvmaster2 Hardware Support 8 09-07-2009 02:20 PM
Suggestions for creating reliable USB-UIRT configuration files jchiso Hardware Support 6 06-13-2005 08:37 PM
Cayars18E creating XML files owilsky SageTV Customizations 14 06-01-2005 02:38 AM
