Old 07-16-2019, 07:41 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
Server not connected
Yesterday, I updated Windows 10 to v1903. Now, when I start the SageTV Client (HD300), I can't get past this message:
The Server "HTPC-Windows10" is configured but is currently not connected.
Waiting for Server to awaken.
Stop Auto-connect
I have this STV version installed on the Server:
SageTV v9.2.1.826 (64 bit)
Java v1.8.0_191
Hostname HTPC-Windows10
IP Address 192.168.1.115
In the Setup Menu, the SageTV Server is "Enabled"
The only repairs I have tried (so far) are:
1. 4 reboots of the Server.
2. Multiple Reboots of the HD300 Client -- including both "Stop/Start" and unplugging the unit.
3.The above was tried on two different HD300 units.
When I "Stop Auto-connect":
Loading Configuration>SageTV Servers shows HTPC-Windows10.
Refresh>Edit Server list shows HTPC-Windows10 - 192.168.1.115
Clicking on the Server Name kills the signal to the AVR (Yamaha RX-A3080) and requires a restart of the HD300. (I can access all of the SageTV recordings -- with PlayOn, Tablo Quad, Plex, etc. -- from the AVR.)
Anyone have an idea of what happened here and how to fix it?
Old 07-16-2019, 08:08 AM
SHS's Avatar
SHS SHS is offline
have try disable firewall to see if that help any
Old 07-16-2019, 08:30 AM
RonBoyd's Avatar
Nope. Didn't help.
SageTV was set to allow through the Windows Defender Firewall but I turned the firewall off anyway before attempting restart.
Two things: 1) I can access the Server with all other applications connected to the AVR and 2) clicking on the Server (in HD300) still shuts the Client down -- requiring a restart of the HD300.
Old 07-17-2019, 05:06 AM
RonBoyd's Avatar
Okay. I have determined that the problem is in the Server SageTV. However, the client recognizes the Server but cannot access any of the files. Another strange thing is that the client can find videos that were long-ago watched and deleted and thinks the current Input Folders are on the previous computer.
Anyway, what is the best way to re-install the program...and where do I find the most current installation file (Windows 64 bit version)?
Old 07-17-2019, 05:20 AM
SHS's Avatar
SHS SHS is offline
https://forums.sagetv.com/forums/showthread.php?t=63009
Make back copy of Wiz.bin from C:\Program Files\SageTV\ some where else
Uninstall SageTV
Reboot
Del the SageTV folder in C:\Program Files\
Reinstall SageTV
Setup everything backup all you tuner, recording folder, media folder and any other folder
Soon as your done close SageTV
Copy the old Wiz.bin over to C:\Program Files\SageTV\ over writing the other one
Restart SageTV
The restore all your fav and etc
Old 07-17-2019, 08:29 AM
RonBoyd's Avatar
Yeah, I was afraid of that. That is a lot of work -- 10 tuners and 5 hard drive storage, for instance. Particularly for something I am not sure about. I was hoping for a "Setting" fix of some kind. I won't get to this project for a few days.
Old 07-18-2019, 05:01 AM
RonBoyd's Avatar
I decided a much easier/faster way to fix the problem -- albeit temporarily -- would be simply restore the computer to an earlier stage. Sure enough. a "restore" to a week ago fixed the issue. The SageTV Client is now behaving as expected.
This is now my dilemma: The last couple of days have been the first time without SageTV for ~10 years. The Tablo Quad did an excellent job of taking over the DVR function and "Play back" was certainly acceptable. PLEX did a great job of accessing the past SageTV recordings... although without commercial skipping and I was very unimpressed with its organizing the files.
It may be an "old dog, new tricks" syndrome but they just aren't SageTV.
The Problem: Now that I know it was the Windows Update that caused the issue and since I am seemingly the only one affected, I doubt there will be a "fix" forthcoming. How do I stop MS from inevitably forcing the update to re-install?
Old 07-19-2019, 03:45 AM
SHS's Avatar
SHS SHS is offline
What OS Builder ver of Windows 10 did go back to ? and do you know off hand the OS Builder ver that causes this and check update history was see if was KB4507453 builder 18362.239 or newer KB4505903 builder 18362.263 ?.
Give this try
https://www.easeus.com/todo-backup-r...ly-update.html
Old 07-19-2019, 08:11 AM
RonBoyd's Avatar
Give this try
Thank you for the Link.
The current version is Windows 10 Home v1809 Bld 17763.615. (this was a surprise because I thought the Pro version was installed.)
Update History shows this:
All on 07/18/2019 and all related to Windows Defender (FWIW, I had restored the machine back to 07/11/2019.)
KB226702 Definition 1.297.1316.0 - Failed
KB226702 Definition 1.297.1319.0 - Installed
KB226702 Definition 1.297.1319.0 - Failed
KB4052623 version 4.18.1906.3 - Installed
And what brought me here (I clicked on it before):
Windows 10 v1903 - Download and Install Now.
Old 07-19-2019, 10:17 AM
SHS's Avatar
SHS SHS is offline
It could any of number of thing Ron, but if you a spare drive try install Windows 10 1903 that way clean or wait for the fall 2019 update.
Old 07-19-2019, 10:58 AM
RonBoyd's Avatar
Yeah, I changed the Registry to disable updates. This machine is used only for SageTV so I have no pressure to update... at this time.
Server Lockups with 3 or more HD300s connected sdsean SageTV Software 12 04-19-2016 10:38 AM
HD200 slow when connected to server ChrisNH SageTV Media Extender 1 09-25-2013 09:52 AM
Turn Off "Connected To Server" mike1961 SageTV Software 1 06-02-2011 04:57 AM
Must HD-PVR be connected to WHS box? Skirge01 Hardware Support 6 01-06-2009 09:59 PM
Problem getting the sage client connected to the sage server modurn SageTV Software 1 07-21-2005 10:37 AM
