Old 05-24-2017, 10:26 AM
mike1961 mike1961 is offline
Looking for Good Web Host Provider
Hello - does anyone know of any good web host providers where I can set up a forum similar to this forum to support a product in my business? I know how to set up a forum but the problem is my web host provider support has gone downhill.
So I'm wondering for all those out there who have their own websites, who they use to host it?
Old 05-25-2017, 08:33 AM
w4rh4wk's Avatar
w4rh4wk w4rh4wk is offline
I actually host my small business on my internet connection at home (its low traffic nothing crazy) but i've used godaddy for a previous employer without issue as well as Amazon Web services. Both are great!
Sage Server: Intel Xeon E5-2660v2; Asus Rampage IV Gene; Win 10 64bit; Nvidia GTX 1060; 16GB; 2 HVR-1250 (OTA HD)
Sage Client 1: i3-2120 3.3Ghz; AMD Radeon HD 7470; win 10; Sage Client 2:Intel Core 2 Duo 3Ghz; Intel GMA 4500; win 7; Sage Client 3: i3-2120 3.3Ghz; AMD Radeon 7000 series; Win 10
Old 05-25-2017, 09:05 AM
Pelicanjoe Pelicanjoe is offline
I use https://arvixe.com/. Good value. They have the standard open source installation scripts. Uses CPANEL, similar to everyone else, so no big learning curve.
Old 05-25-2017, 02:39 PM
samgreco samgreco is offline
I have a dedicated server at Big Brain Global and they're great. But I think that and Cloud is all they do now. So if you're looking for shared hosting or a VPS, they won't be able to help.
You might want to check out WebHostingTalk.com. Lots of discussions and actual customer reviews if you can slog through all of the other stuff. And there are always deals in their "marketplace" area.
But if it's a bad host, they'll tell you.
Old 05-31-2017, 11:14 AM
SWKerr SWKerr is offline
If you have modest needs then Google Domains works well.
You get your domain managed by google and you can integrate email into gmail.
The have a number of free web hosting options if your needs are simple or you can link to external hosting providers if desired.
Old 07-01-2017, 10:40 AM
Linode.com is an option as well, since I last looked, it seems they have a $5/month option which gives you a "1 core" CPU, 1GB RAM, 20GB of SSD storage(includes OS install), 1TB/month of transfer, 40GB/s in, and 1,000 GB/s out.
I know several people who use them, and the systems are stable, about the only thing that should normally knock them offline is something you do to them(or allow to be done) as an admin.
Keep current EPG provider? valnar SageTV EPG Service 2 04-21-2017 05:37 AM
Can anyone host a mirror of SageTV hosted plugins? Slugger General Discussion 48 10-19-2012 10:01 AM
Can't change weather provider Dargason Gemstone for v7 4 09-19-2012 05:23 PM
Comcast Host ID - Centon InfiniTV 4 & WHS2011? KarylFStein Hardware Support 14 07-11-2012 09:51 PM
I Need a New Shared Web Host Crashless The SageTV Community 8 06-28-2009 01:15 AM
