Old 05-01-2008, 07:04 AM
neil.prasad neil.prasad is offline
Java error: java.lang.NullPointerException
Hi,
I just decided to try the trial of SageTV and I can't get it to start. When I try to start the program in gets to the point of "SageTV core is initializing" and then a Java error appears:
An exception occurred in Java:
I've re-installed Java to the latest version twice and re-installed SageTV as well, does exactly the same thing.
I've tried google searching the issue and having a look round the forums but didn't find anything. Anyone know what the problem is?
BTW, I'm running Vista Ultimate 32-bit on an Athlon64 3400+ with 1GB RAM and a GeForce 6800GT. The TV tuner is a USB MSI DIGIVOX mini II. I don't kow if that is a compatible tuner or not but that was the whole point of using the trial! I have the feeling the error is not related to the card though.
Neil.
Old 05-01-2008, 12:11 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Please submit a bug report here: http://sagetv.com/bugs.html
We'd like to get more information from you on why this is occuring.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-01-2008, 03:52 PM
Thanks. I've done that and look forward to some ongoing support.
Old 07-27-2008, 09:06 PM
Thraxius Thraxius is offline
Same Issue
Let me know what they find for you. Because I am having the same issue.
Old 09-30-2011, 10:21 AM
joh3004 joh3004 is offline
I'm having this issue as well. I'm using Windows 7 34 bit.
Also, recently I updated java without completely closing sage, and as a result my wiz.bin was corrupted and I needed to roll back to an earlier version.
After the roll back, sage was working fine for a few days, and now I get a java.lang.nullpointerexception error whenever I try to launch sage.
Any ideas on how to resolve this?
Man, I should never update java...
Old 12-01-2011, 08:25 AM
kruzerman kruzerman is offline
I just started having this issue on all of my clients this past week. I even had the error after reinstalling windows and applying all windows updates. I did not update Java so my theory is the issue is somewhere in Windows Update. I just did another fresh install and I am turning off all updates. Hopefully this will work. I would hate to have 2 unusable clients.
Old 12-12-2011, 04:42 AM
sausages sausages is offline
Hey did anyone figure out why this message was appearing or can they point me in the direction of a thread that looks at Land Insurance more in depth if there is one?
Old 12-13-2011, 01:08 PM
Originally Posted by sausages View Post
Hey did anyone figure out why this message was appearing or can they point me in the direction of a thread that looks at it more in depth if there is one?
My best guess is that it is an issue with a recent windows update. On the last client i fixed, I reinstalled windows and forgot to turn off automatic updating. I let it sit for some time and when I came back, I installed Sage and boom! I got this stupid Java error again. There are too many updates to figure out which one is causing the issue but i could probably narrow it down to September since that was the last time i updated before November when my issue started. The reason I did the update was because Sage was going to a black screen when i would wake the computer from sleep using an MCE remote. I finally have a client working again but the UI is VERY laggy on a C2D 6550 that never really had any issues until now.
Old 12-13-2011, 07:43 PM
firenice firenice is offline
@ sausages & kuzerman
My best guess would be that the New Java 7 update isn't capatible.
I seen references that the Java 7 update doesn't play well with Sage.
BTW.. check the dates of the posts.
Java update on WHS version of Sage? Slipshod SageTV Software 4 04-14-2008 01:03 PM
Extender: Different property files are accessed between STV code and Java lib Morgan111 SageTV Studio 1 02-12-2008 08:49 PM
Java - Update or not ? Ken C General Discussion 8 12-28-2007 02:03 PM
Java question matrix35 General Discussion 0 12-04-2006 04:12 PM
Java problem with AwtToolkit Ctrl-Z SageTV Beta Test Software 0 11-01-2005 09:32 AM
