Old 08-19-2007, 09:56 AM
tfurlong's Avatar
tfurlong tfurlong is offline
Feedback on 6.2.6 Recording Schedule
I have a dual-tuner (STV) configuration, and I have grown accustomed to the parallel format for scheduled recordings. I like it because it's a good indicator of the availability of my tuners.
In 6.2.6, the parallel view doesn't have enough room to display the day & time of the scheduled recordings. Instead, I just see the day (e.g. "Sun..."), so I have to switch between view modes to see times. I hope this can be fixed before release because I really liked it the old way.
Old 08-19-2007, 10:21 AM
I'll make a note to check it out... to see if I can reproduce it for better testing of a change, what resolution are you using, or is this on an MVP client?
Old 08-19-2007, 12:02 PM
tmiranda's Avatar
tmiranda tmiranda is offline
I was going to mention the same thing... On my MVPs you can only see the Day and not the time.
Old 08-20-2007, 02:09 PM
I believe this is fixed for the next release. I also fixed the By Day view so the date & time should be fully visible there too.
Old 08-21-2007, 07:27 AM
tfurlong's Avatar
I noticed it on the SageTV system, not a client. And I run at 640x480. But t looks like you found it, so thanks!
Time recording problems bazan SageTV Software 0 10-31-2006 11:41 AM
having a recording issue ... ViAo Hardware Support 10 10-23-2006 09:58 PM
How to STOP a recording (as opposed to cancelling) johnb41 SageTV Software 1 10-03-2006 08:36 PM
Feature Request: HDTV Recording Priority rsagetv99 SageTV Beta Test Software 19 03-10-2006 09:31 PM
No time displayed in recording schedule wjohn SageTV Software 5 11-28-2005 01:17 AM
