Go Back   SageTV Community > SageTV International User Forums > SageTV Australia/New Zealand
SageTV Australia/New Zealand SageTV and SageTV Recorder Users from the Land Down Under - This forum is for you to post about specific issues using SageTV software in Australia and New Zealand.
Old 07-27-2009, 03:36 AM
mickp's Avatar
mickp mickp is offline
Freeview oz channel logos
Hey there,
I went on a quick search to download some new logos for the additional stations on the weekend but didn't manage to find anything much. I ended up cutting the attached collection from screenshots of the Freeview site's flash pages.
I thought I'd post them here just in case they're of use to someone. Here's a pic;
Unfortunately I found that the guide in SageMC was scaling them to be smaller than I'd expected and was also taking up more room for the channel column than I'd anticipated. After some playing about in Studio I think I've managed to tweak the guide proportions to work with most settings. I've included an stvi resizeGuideForLogos.xml in the zip file below if you'd like to make the same changes.
Here's a before and after of the guide layout on my system;
Mick.
PS: the jpg files need to go into your "C:\Program Files\SageTV\SageTV\ChannelLogos" directory and need to be renamed to match the channel id's you're using.
Old 07-28-2009, 05:57 PM
peterjb peterjb is offline
Thanks for this.. I was thinking it was about time to upgrade my logos..
Cheers
Peter
Old 07-29-2009, 03:19 AM
mickp's Avatar
Cheers
Peter
No worries,
Let us know if you have any problems with the scaling.
Mick.
Old 07-30-2009, 06:11 AM
maninblack_30 maninblack_30 is offline
Mick, do you know if there is a way to get rid of the channel name, and leave just the logo in Sage with the default STV?
Fr
Server:HP DL380 Dual Quad Xeon E5530 2.4Ghz per core, 64GB RAM, 2x Hauppauge HVR-2200 tuners (4 total) 146GB mirrored system drive running Server 2012 R2, 3TB storage HDD space (7x500Gb),
Clients:1 STX HD-100, 1 HD-200, 1 HD-300 for main TV room connected to Pioneer SC-LX72 with Tannoy MX4 mains, MX3 rears and MXm centre (or center!) and Yamaha YST-SW160 subwoofer, Bravia 55' LCD
Old 07-30-2009, 03:32 PM
mickp's Avatar
Fr
Sorry. The only option that I can see in the default stv is to set whether they appear on one or two lines. This setting is in the options (ctrl-o) for the guide. Someone who regularly uses the default stv might have a better idea.
It should be fairly easy to modify this in Studio. I'll try to take a look sometime on the weekend if nobody chimes in with an easier way.
Mick.
Old 07-31-2009, 07:02 AM
hoadie hoadie is offline
Thanks mate, I was too lazy to do this myself
Old 07-31-2009, 08:27 PM
mickp's Avatar
Fr
Hey there,
As nobody has chimed in with an easier way and I've not been able to find it, I've gone ahead and removed the channel name and number from the default stv.
As with the rescaling import for SageMC above, someone who knows what they're doing could actually add a setting for this rather than just deleting and hard setting items as I've done. For the moment though it's easy enough to back out changes by reloading the previous version of the stv I guess.
Here are some pics:
Mick.
PS: Ooooh. I like the way that the default stv handles plugins these days.
File Type: stvi RemoveStationNameNumberFromStandardSTV.stvi (2.0 KB, 381 views)
Old 07-31-2009, 08:41 PM
Thumbs up
Mick, thankyou soo much for that, I've never used Studio before, I'm too afraid of breaking things!
I'll try this this afternoon after I migrate everything over to WHS.(just took delivery of a 5 disk in 3 bay SATA cage from the States - going to try WHS)
Fraser
Old 07-31-2009, 09:12 PM
mickp's Avatar
Fraser
No Worries. Good luck with the whs system. I've been wondering if it's worth going that way for my next rebuild.
Mick.
Old 08-01-2009, 01:48 AM
Well, I got everything setup to the point of setting up the xmltv guide, and the channels in Sage, and I've had enough!
I put the old boot drive back in, so we're back to normal for now.
I'll have another go at it fresh tomorrow, then it's just the migration of recordings from 4 drives into the drive pool.aser
It would be so much easier if we didn't have 200 favorites and two and a half terrabytes of recordings.
I'll let you know how WHS goes after I't's settled in Mick
I'm now going to try your little stv on my hd200.......
Fraser
Old 11-28-2009, 11:15 PM
mickp's Avatar
Updated Freeview logos
Hey there,
Just noticed that I didn't have a logo up for the new 7two channel so thought I'd just go and just add the missing one. Unfortunately (or fortunately depending upon how you look at it) the Freeview folks have gone and updated all of the logos on the site
Below is an updated set of Aussie Freeview logos. The dimensions are slightly different from the previous set but a quick check seems to indicate that they work as expected with the layout hacks mentioned above.
Prime haven't revealed what their version of 7two will be yet so there will probably be another update when this becomes available. I think this is happening sometime in December.
As with the previous set they need to be renamed to match the callsigns that you're using and copied to your c:\program files\sagetv\sagetv\channelLogos (or equivalent) directory.
Mick.
PS: I kinda prefer some of the logos from the previous set so may muck about with creating a hybrid of the two sets. Will post them up here if I do.
Edit: 7TwoPrime is on the air now. I've added an additional attachment with this logo.
Edit: ABC News 24 logo also attached below.
Old 12-02-2009, 01:42 AM
milesbrennan's Avatar
milesbrennan milesbrennan is offline
Mate these look great...
I use Linux, so once we've got the DVB-T HDHR beta testing sorted out, I'm going to have a play with these.
Thread book marked...
Old 08-07-2010, 10:54 PM
mickp's Avatar
ABC News 24 Logo
Here's a matching logo for ABC News 24 courtesy of the folks at freeview.com.au.
Mick.
Old 08-08-2010, 12:06 AM
Mick,
Thanks for that.. Any chance you can re-patch your default stvi changes? The latest stvi update for v6 breaks it and it will no longer load. Removing it gives me back the old cr*p epg...
Cheers
Peter
Old 08-08-2010, 10:01 PM
mickp's Avatar
Mick,
Cheers
Peter
Hi Peter,
Sorry. I hadn't realised that this had been borked. I'll try to take a look at this in the next day or so. I've cut over to Sage 7 so will be able to load the Sage7 version of the Sage 6 stv (if that makes sense) but won't be able to do this on V6. Hopefully this will be similar enough to work. Otherwise I might need to describe how to make the changes.
Mick.
Old 08-13-2010, 07:16 PM
Mick,
No worries.. I might just have to update to V7 as an alternative
Cheers
Peter
Channel Logos brettrein SageTV Software 11 08-27-2008 01:16 AM
Channel Logos planetc SageTV United Kingdom 2 04-19-2008 08:10 AM
Channel logos craigap SageTV Software 1 01-04-2008 11:01 PM
Freeview channel changing, RS-232? darthfoolish Hardware Support 0 12-04-2005 10:55 AM
Freeview TV Logos ukmgranger General Discussion 2 08-19-2005 10:58 AM
