Go Back   SageTV Community > SageTV International User Forums > SageTV Australia/New Zealand
SageTV Australia/New Zealand SageTV and SageTV Recorder Users from the Land Down Under - This forum is for you to post about specific issues using SageTV software in Australia and New Zealand.
Old 12-26-2011, 03:15 AM
dcallagh dcallagh is offline
SageTV Service will not tune 9 in melbourne, SAGETV program will
Hi all,
A strange one, I run a scan and I get all channels but 7, including all the 9's (GEM etc). I can test the channel in the setup, but once I go to view the channel, it either does not tune, or tunes 11 in as 9!!
I found that when I turn the service off, and stop the use of the sagetv service, SAGETV will tune all the 9's without a problem.
Help - I have renamed the .frq files, done a rescan, rebooted etc.... no luck.
Old 01-17-2012, 01:28 AM
maninblack_30 maninblack_30 is offline
Did you ever sort this?
Server:HP DL380 Dual Quad Xeon E5530 2.4Ghz per core, 64GB RAM, 2x Hauppauge HVR-2200 tuners (4 total) 146GB mirrored system drive running Server 2012 R2, 3TB storage HDD space (7x500Gb),
Clients:1 STX HD-100, 1 HD-200, 1 HD-300 for main TV room connected to Pioneer SC-LX72 with Tannoy MX4 mains, MX3 rears and MXm centre (or center!) and Yamaha YST-SW160 subwoofer, Bravia 55' LCD
Old 02-04-2012, 06:02 PM
I'm having the same problem with Ch31!!
SageTV program discovery works but not when using service impro SageTV Software 2 01-28-2009 02:33 PM
6.1.4: SageTV, Vista, & MVP work perfectly but only WITHOUT SageTV Service running! sjgore SageTV Beta Test Software 0 03-11-2007 11:25 AM
When running as service why does starting Sage UI say SageTV Service is initializing? GollyJer SageTV Software 2 12-27-2006 09:59 AM
SageTV 4.0 service - opening Sage UI hangs running SageTV client Surtr SageTV Software 1 11-10-2005 01:25 PM
SageTV hangs on start if SageTV Service is Enabled/Running zwombat SageTV Software 10 11-08-2004 02:57 PM
