Go Back   SageTV Community > SageTV International User Forums > SageTV Australia/New Zealand
SageTV Australia/New Zealand SageTV and SageTV Recorder Users from the Land Down Under - This forum is for you to post about specific issues using SageTV software in Australia and New Zealand.
Old 11-04-2013, 07:05 AM
routerunner's Avatar
DVB Decrypter & Card Client plugin's tester wanted
Hi,
I've recently developed a plugin for SageTV which allows to descramble encrypted channel natively within SageTV and I was wondering whether some SageTV's user from Australia & New Zealand will be willing to test this plugin for me and see whether it does work properly or not in exchange of my deep and sincere gratitude
Please look at the project thread HERE for further information and let me know if you need any assistance with the setup...
Eddy
Old 11-04-2013, 11:52 AM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
Eddy, I've had problems with the later oscam builds, including the one you include in the plugin with a message something like "card system not supported". I've never really had any serious time to investigate.
I use build oscam #6590 with my SageTV/DVBLogic setup. I'll try and find some time to look into it a bit more.
John
Old 11-04-2013, 01:13 PM
John
Hi John, to be quite honest I was counting on your reply
Please use your OSCAM distribution by all means, the only thing please make sure to have a copy of your distribution inside "../SageTV/SageTV/CAM" as my plugin reads the "oscam.server" from there and produces the right "oscam.user" and "oscam.conf" there as well.
Also, you don't need to uninstall DVBLogic or unregister the MDAPI.ax filter (I assume you're using this filter to descramble) as my plugin, as part of the installation process, will register the new filter and will change the Windows registry key entry to point to my filter DVBDCC.ax, but you do need valid SageTV .FRQ files, one for each of you tuner.
Looking forward to hear from you.
Cheers
Eddy
Old 11-14-2013, 05:21 PM
John
Hi John,
please let me know whether I can help you with that
cheers
Eddy
Old 11-14-2013, 10:37 PM
JREkiwi's Avatar
I did get to have a play with the current oscam build and found that I needed to specify the Boxid to get past the "card system not supported" message.
Unfortunately in order to use the current oscam version I need to use a recent set of cygwin dlls and I get slow ecm times when using them.
Old dlls:
1 stream ecm = 300ms
2 streams ecm =300ms
New dlls:
2 streams ecm =600ms which results in picture breakup
Also had a play with using a raspberry pi as a card server
1 stream ecm = 250ms
I still plan to try out your plugin, but it's tricky matching my free time with time SageTV isn't busy.
John
Old 11-15-2013, 03:08 AM
Old dlls:
New dlls:
John
Hi John,
thanks for the update.
You don't need to update the OSCAM in order to try the new plugin, just make a new directory called CAM under your SageTV installation directory, copy all your current OSCAM files there.
Cheers
Eddy
Old 12-11-2013, 04:43 PM
John
Hi John,
can you please tell me which encryption system do you have in New Zealand? Is it IRDETO by any chance? If so do you mind emailing me your OSCAM files for inspection at the address below:
edoardo [dot] rossi [dot] home [at] gmail [dot] com
Eddy
Old 12-12-2013, 10:39 PM
JREkiwi's Avatar
Eddy, it's NDS (Videoguard) here.
John
Old 12-14-2013, 10:24 AM
John
John,
thank you very much, I sure have no problem with Videoguard here in the UK.
Eddy
Old 01-24-2014, 03:17 AM
plnewton plnewton is offline
Hi guys
I am curious to know what encrypted services you wanting to test with?
Here is Australia there is pretty much only foxtel and the cards are matched up t the boxes now and will not work in anything else
I had mine setup with sage and a tuner card for a while before all the changes took place but since it has been back to the standard set top box
Old 01-24-2014, 03:46 AM
Hi,
I don't know about Australia, but I do know that in New Zealand you can watch Sky channels with a smartcard inserted in a card reader and OSCAM with SageTV and just wanted to know whether my new approach does work properly
Eddy
Plugin: DVB Decrypter & Card Client routerunner SageTV v7 Customizations 494 07-29-2019 11:09 AM
Plugin: DVB Decrypter & Card Client routerunner Customization Announcements 28 01-13-2019 01:44 PM
Wanted: SageTV Client License pbdickey SageTV Marketplace 8 07-01-2013 01:18 PM
Linux HDHomeRun DVB-T beta tester wanted donkey SageTV Beta Test Software 0 10-09-2009 06:28 PM
DVB-S with SBDARecorder beta tester wanted AndersNolberger Hardware Support 20 05-09-2006 03:11 AM
