Old 05-14-2020, 05:40 PM
pjpjpjpj pjpjpjpj is offline
Software question
Is there freeware out there that can take two copies of a movie and grab the audio from one and the video from the other and combine them into a single output file?
For instance, if I download a 1080p version of a movie from PlayOn (limited to stereo), and I already own the DVD and have it in SD but DD5.1 sound, I would like to take the 1080p from the downloaded file and the 5.1 sound from the DVD rip and combine them into a 1080p/DD5.1 movie.
Is there freeware that can do this easily (and well)?
Old 05-14-2020, 07:54 PM
I think VideoReDo does this but you have to pay for that. But sometimes the timing could get slightly off as one of the files might be running a bit fast.
Old 05-14-2020, 08:48 PM
Thomas Wischgol's Avatar
Thomas Wischgol Thomas Wischgol is offline
ffmpeg also allows you to demux both videos and then mux the streams you want into one video file. ffpmg is a little cryptic to use. An alternative I have used recently is MP4box. There are also GUIs for MP4box if you do not like command line parameters.
Old 05-15-2020, 09:00 AM
poto poto is offline
MakeMKV has freeware and "deluxe" paid versions that will apply MKV wrapper to some video formats.
Once in MKV format, MVKToolNix can mix & match video, subs & audio as needed. Be aware of differing frame rates between 2 source files, as stretching/compressing may be needed to match in target output.
Videohelp is a great resource for finding more obscure tools.
Old 05-15-2020, 08:34 PM
Thanks, all! I will check these out.
Question about software key jstang SageTV Software 2 10-02-2012 01:59 PM
noob license and software question jplatt10 SageTV Software 4 03-17-2010 02:13 PM
noob Software License Question.. shootler SageTV HD Theater - Media Player 1 12-27-2008 01:59 PM
Recommend Nvidia 6800? hardware & software question korben_dallas Hardware Support 2 02-04-2005 02:01 AM
(Possibly) Stupid hardware/software decoding question re pvr350 GrayGh0st Hardware Support 6 08-18-2004 07:39 AM
