Old 09-26-2020, 08:06 AM
fbures fbures is offline
STV suddenly stopped playing MKV files
STV V9.1.9.778
Windows 10-64bit
Java 1.8.0_261
It happened couple of days ago. I have not changed anything, nor I installed any new SW. With the exception of Windows updates there were no installations on this system for a very long time.
Any attempt to play any MKV file returns:
sage.PlaybackException: ERROR (-3,0x80040241): There was a problem accessing the filesystem for playback.
I can play the same MKVs with VLC with no problem. I can access the files normally by any other means.
The problem is 100% repeatable.
Any advice would be greatly appreciated. My whole video archive is in MKV format.
Frank
Old 09-26-2020, 08:42 AM
KryptoNyte's Avatar
Hi, Frank. Please grab and post a screenshot of the screen that I'm showing on the attached. Then click on "Default" for H.264 Video Decoder Filter and grab another screenshot of the options that appear there.
Just to clarify, are you attempting to play this while sitting at the server itself, or from another PC client on the network?
Old 09-26-2020, 08:45 AM
KryptoNyte's Avatar
Whoops, the above post probably won't help, maybe ignore it.
Check here:
https://forums.sagetv.com/forums/showthread.php?t=36600
Old 09-26-2020, 08:51 AM
KryptoNyte's Avatar
Similar issue here:
https://forums.sagetv.com/forums/showthread.php?t=27385
Old 09-26-2020, 09:09 AM
SOLVED
I updated to STV 9.2.2 and the problem disappeared.
Weird...
HD200 suddenly stopped working Ron SageTV Media Extender 9 06-07-2012 02:49 PM
Help. . .suddenly More than 2 HD-PVRs stopped working sdsean Hardware Support 17 11-07-2011 07:18 AM
"Trailers" Suddenly Stopped Working Savage1701 SageTV v7 Customizations 4 10-24-2011 07:21 PM
.avi files suddenly stopped working morpheus SageTV Software 4 05-21-2006 02:37 PM
DVD playing - stopped working... oshapir SageTV Beta Test Software 2 02-06-2005 03:14 PM
