Old 10-04-2020, 01:14 PM
AlphaCrew AlphaCrew is offline
Why?
Why am I seeing this conflict? I have a Ceton 6 tuner card and it appears it's the only program on that date?
The first picture is from the conflict resolution page, the second is scheduled programs by day.
What am I missing?
Old 10-04-2020, 01:20 PM
KryptoNyte's Avatar
I don't know if this is what's happening in your scenario, but when I see something like that once in a while, my Ceton 6 pcie just disappears (or some of the individual tuners) for reasons that I can't explain. I have to power the machine completely down for 20 seconds and start it up to get it back to 100%.
Old 10-04-2020, 01:45 PM
Thanks for the suggestion, I will give that a try.
I can confirm going into the guide I can select 6 shows to record without any issues...
Old 10-04-2020, 02:01 PM
KryptoNyte's Avatar
If you can record 6 shows simultaneously otherwise, then losing the tuner probably isn't the issue.
Old 10-04-2020, 03:09 PM
As it turns out you are correct, I powered the server down, unplugged for 5 min and powered it back to see the same conflict..
I set the Watched flag and of course it went away..
Old 10-04-2020, 03:22 PM
KryptoNyte's Avatar
I've had some strange recording conflicts over the years that I was never able to reason through. They weren't critical and I usually resolved them the same way you did.
