Old 10-14-2020, 04:56 PM
Slack's Avatar
Slack Slack is offline
Placeshift / Streaming Question
I find myself out my football market for a while.
I'm interested in the current state of affairs with accessing content from my server at home.
Searching for the old topic of place shifting reveals very old threads. I never used it in the past when it was a Sage thing.
I perhaps wrongly am assuming that things are better with version 9. But I dunno.
I tried streaming through the web admin "Sage Webserver version 2.43". because it's there... but on my side it states I don't have VLC installed - but I do.
Is there a sticky about this or is it just a waste of time. Server box indicates 10 megabit upload.
I read some threads from like 2011 about VPN'ing a client (pc client) to connect. But they were not very promising.
Old 10-14-2020, 06:44 PM
hb4 hb4 is offline
It's in Beta, but you might try a firestick 4K. I've been using it, and it's working pretty well for me although I am seeing halts which I believe is due to my paltry 6mbs DCL line at the remote location.
https://forums.sagetv.com/forums/sho...87&postcount=1
Server: Intel i5-2400 @3.1GHz 4 cores Windows 8.1 Pro, Sage 9.2.1 with Comskip
Capture: OTA; Comcast to HD-PVR, HDHR, HDHR Prime with Firmware version 20150826 and OpenDCT version 0.5.13 beta
Storage: 1Tb HD on Server, 2Tb Buffalo NAS
Network: Gb Buffalo Router, Gb 8-port Netgear Switch connected to Server, HD-200, NAS, HDHR, Prime, LAN
Playback: HD-200, Server to HDTV; HD-300 and Emby for off-site playback
Tech Level: Hobbyist
Old 10-14-2020, 07:51 PM
Have you tried using SageTV Placeshifter on your remote PC? That is probably the best solution but it doesn't work so well for 1080i content.
I assume that you will be watching in realtime? If you are fine watching a bit delayed then you could use somthing like AirVideoHD as a client on an iOS device. You often have to reload the file every few minutes when you hit the end of the file - or at least the end of the file as defined by when you started watching the game.
Old 10-15-2020, 02:04 PM
Slack's Avatar
This is a client. I have a client on the PC with me.
Not sure what ports to forward.
No. I assumed placeshifter is dead - and you'd have to have a license for it. I was thinking there was some awesome sauce built into v9.
I had limited success feeding the stream url link from the web server into VLC directly via 'open network stream'. It seemed to buffer / stutter HD content. If I paused it for a bit it would then play longer before the next hiccup.
My other option may be to use VPN and folk over some money to NFL.com and just stream it like I was in Finland or something.
Did that once when in Finland it was quite cheap at the time.
Old 10-15-2020, 02:22 PM
Placeshifter is not dead. See V9.2.1 here: https://bintray.com/opensagetv/saget...agetvwin/9.2.1
You haven't needed licenses since we went to Open Source.
I use Placeshifter all the time, but only on my LAN. For remote viewing Placeshifter should work better than Client.
Old 10-15-2020, 02:27 PM
Tiki's Avatar
Tiki Tiki is offline
The full Client is not meant to work remotely across a WAN. I think it needs to be on the same subnet as the server. The server does not transcode anything for a full Client - it just tells the Client where to find the file so the Client can play it back.
For remote viewing, I think the only options are the Placeshifter, an HDx00 extender, or the Android mini-client. All of these are built on the mini-client architecture and behave similarly (though each has its own way of handling the playback that is unique to its hardware platform).
There have been 2 or 3 web servers created for Sage. These were all unofficial, user-created add-ons and not part of a basic Sage install. I havenít tried any of these in a long time, but I think at least one of them provided a way to download (and possibly playback) a Sage recording. I could be wrong, but I think the playback relied on a specific version of VLC being installed and may not have worked if you were accessing from an iPhone or something.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 10-15-2020, 02:31 PM
hb4 hb4 is offline
Placeshifter is not dead; I have been using it remotely forever, and changed from the PC version to a spare HD-300 about a year ago (there is a V9 version downloadable, no license required); but now I'm using the firestick 4K because the image is much better. The downside is that it is a beta client so the settings are changing often. For ease, I'd recommend Placeshifter. Both the HD-300 and the miniclient use Placeshifter settings to authenticate the first time they're used.
Old 10-15-2020, 07:49 PM
Slack's Avatar
So placeshifter is now working.
There is a hit on image quality - but it's responsive enough, and has niceties like comm skip breaks.
( I also tried no transcoding setting, no big improvement).
The VLC stream was full res - wonder if that would last for 3 hours.
Old 10-16-2020, 11:43 AM
hb4 hb4 is offline
You can get better quality remote playback with Emby; MCEBuddy will move them to an Emby-friendly folder and naming structure, plus it can re-comskip them. I think it often does better comskipping than Sage, and it removes them from the recording.
Old 10-17-2020, 02:32 PM
Slack's Avatar
Yes indeed.
Thanks for that.
Emby installed - nothing else. Big improvement. I can live without the comskip for the time being.
Old 10-18-2020, 12:36 AM
VCRUser VCRUser is offline
If you move them to an Emby-friendly folder, will Sage also know where to find them for playback through Placeshifter, Client, extender, etc.?
Server: Windows 7 SP1; 4gb RAM; 2TB SATA. Dell GX745. Inputs: Haup. 850 & 950Q on ATSC; Haup 1600 on ATSC & Comcast DTA with USBUIRT. Haup 1800 on ATSC. Sage 9.
Old 10-18-2020, 10:28 AM
hb4 hb4 is offline
I have MCEBuddy set up to make a copy and place it in a (more or less) Emby-friendly structure. Some other Sage/Emby users may have way to use the same recording file for both; I'd be interested in hearing about it if there is.
v7 media (audio) streaming question robmarch SageTV Beta Test Software 1 06-07-2010 11:01 AM
Client Streaming Question - Imported Videos InsertHere SageTV Software 1 08-04-2005 09:37 AM
streaming question. wm21online SageTV Software 4 02-02-2005 11:51 PM
Network Streaming PQ Question edgley SageTV Software 4 03-07-2004 02:53 PM
TV streaming question edgley General Discussion 8 02-03-2004 06:59 PM
