SageTV Clients Development This forum is for discussions relating to SageTV Open Source Clients Development. |
Android miniclient - "boots" Shield
Since upgrading to 1.11.0, on occasion, and randomly, when playing a recorded show (from HD-PVR), the screen goes black for a second or two, the word "android" appears in big letters, and then the Shield returns to its main screen. It is almost like the Shield is rebooting, but it is not a complete reboot, since the Nvidia logos don't show - just the word "android".
I'd say the MTBF - mean time between failures - is on the order of 15 minutes. Shield is fine - no problems with Netflix, Plex, etc. Never saw this behavior with the previous miniclient version. Any hints/suggestions? |
Is this the Shield Pro or standard Shield?
Josh
Projects I am currently maintaining SageTV Andoid Client Media Format Parser Plugin JavaFFmpegLibrary SageTVTranscoder If you like the work I am doing and would like to support it you can become a Patreon member. |
It is a regular Shield, not the Pro.
I am running IJKPlayer, in Fixed streaming mode. |
i'm also getting strange behavior with the latest client and the Shield Pro.
i get occasional lockups, which i think are related to: multiple quick remote clicks resuming programs previously started other stuff often, the screen locks up, then eventually goes back to server login page with a 'connection lost' message on the screen. i CAN get back to the shield pro home page and use other apps, so it seems only the sagetv client is getting locked up. this is happening 20-50% of the time, so this is not a rare occurrence here. if you need a log file of something, let me know and i'll upload (please specify which log files you want to see)
Q: dad, when will you stop changing all the electronics? A: never, so you might as well get used to it. Last edited by cat6man; 06-23-2022 at 02:46 PM. |
https://forums.sagetv.com/forums/showthread.php?t=64725
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 06-23-2022 at 03:23 PM. |
nope, no fan art
i have thumbnails but that never had a problem until this latest drop of the client
Q: dad, when will you stop changing all the electronics? A: never, so you might as well get used to it. |
Did the latest version I just released get installed yet? I think I fixed the issue.
I am up to 1.12 on my FireTV.
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. |
1.12 here as well.
anyone know where the sagetvclient.log.txt file is stored on the shield pro?
Im having issues as well with 1.12
I have 3 regular shields that will go black and exit sage and I sometimes have to power off the shield and restart. Im using IJK fixed streaming I roll back to 1.9.3 and its stable.
SageTV V9.xx 2 x HD300's, 2 x Nvidia Shields Running Mini Client |
Thanks, Josh
Ok
I just tried to play live tv and it froze at 9:08am EST today under my username. Thx
Josh
i added a usb stick but still cannot set the logging option in the client settings. (kodi and others apps do see the usb stick)
log files for 'cat6man' are now available, approx 3:42pm eastern time.
3 failures out of 5 attempts fail to play previously recorded show plays previously recorded show fail to play previously recorded show watches current program ok fails to watch current program all the fails lock the screen and drop back (eventually) to the sagetv server selection page thanks for all your work here!!!!!
Q: dad, when will you stop changing all the electronics? A: never, so you might as well get used to it. Last edited by cat6man; 06-26-2022 at 04:18 PM. |
The app didnt crash, screen went black and ui was unresponsive. If i restart the app it works fine for a while (10-15 minutes)
![]() 1. You are running 1.12.0 version of the client correct? 2. Are you also using IJKPlayer? 3. Does this only happen on LiveTV? 4. If only on live tv, what type of LiveTV files? .ts/.ps h.264/mpeg2? Do you possibly know how to run ADB to capture a debug log of the event? Thanks, Josh
Thanks, Josh
I have 4 shields, two of them where locked on 1.9.3 and the other two started having problems this week on 1.12. I imagine they auto updated from 1.11 this week, if there was a problem with it I would of heard from my wife!
"Backdrops" "SageTV" "Covers" folders - what's creating them | mp328 | Sage My Movies | 4 | 09-20-2010 05:31 PM |
"Not Manual Recording" filtering doesn't work in SageTV's "Upcoming Movies" menu | vince100 | SageTV Customizations | 3 | 11-23-2009 03:56 PM |
"Set defaults" for Series forgets "Keep"/"Auto-delete" setting | maxpower | SageMC Custom Interface | 9 | 05-14-2008 09:44 PM |
MVP boots, live tv and video files show "trial" - PAL issue? | maninblack_30 | SageTV Media Extender | 2 | 08-04-2006 05:07 AM |
Stutter/Jitter using A180/Vbox and OTA? Check signal "Strength" not "quality" | svemuri | Hardware Support | 0 | 12-13-2005 10:51 AM |
