Old 01-18-2016, 09:34 AM
personalt's Avatar
personalt personalt is offline
Directv Serial Control worked on win10 upgrade but not win10 reinstall
I upgraded my windows 7 system to windows 10 and the serial controls worked ok after the migration.
Some non-sage related stuff didnt work well after the upgrade so i decided to do a fresh install. After the fresh install the serial control of the directv box stopped working. The comm port changed and I addressed that however there was some errors in the log that basically said, 'we think the channel changed worked but we are not sure.' the channel changes didnt work, however I can tell that everything is basically hooked up okay because when i disconnect the cable going in to the box I do lose the message that indicates there was a nack.
I ended up spending the $15 for a serial card but has anyone else seen issues in windows 10?
Old 01-19-2016, 12:33 PM
SHS's Avatar
SHS SHS is offline
Man you must have an old directv box if your useing serial controls
Old 01-20-2016, 09:57 AM
personalt's Avatar
It is really USB to serial on the directv side, but yet I guess the box is a good 5-6 years old.
I was going to try to use the IP controls but I didnt really understand how to set it up. I saw two threads on it setting it up and both had slight different instructions. The two instructions pointed to two differnt set of dlls. One set of instructions pointed to some batch files and one solution needed plug in.
Do you actually need a plug in to do the ip channel switching?
Old 01-20-2016, 02:16 PM
SHS's Avatar
SHS SHS is offline
What is box model do you have ?.
You will need a Ethernet cable going to router or DirecTV Cinema Connection Kit and possable a DECA device.
I like Ericvic plug-in better.
But I no have DirecTV so I will not be able help with set it up.
Serial USB Control of DirecTV D12-300 davephan Hardware Support 11 07-01-2015 01:32 AM
DirecTV d12-300 Serial Control kd5crs Hardware Support 1 08-16-2009 07:47 AM
DirecTV serial control on the Mac GregT SageTV Mac Edition 1 01-30-2009 04:04 PM
DirecTv H20 Serial Control Steve52 Hardware Support 2 06-06-2007 02:01 PM
serial control of directv draven SageTV Software 1 01-04-2004 01:13 PM
