Old 04-30-2008, 07:08 AM
aperry's Avatar
aperry aperry is offline
Media Center Video In The Wrong Place
I have one of my folders for videos defined as "S:\Videos". In that folder, one of the sub-folders I have is "TV\Frasier", and it contains the entire series that I have dumped from my DVD's for convenient watching.
The problem is that one of the AVI files in there shows up in the main Videos area in Media Center. All of the rest of them show up in the TV\Frasier sub-folder, just this one is in the wrong place.
I've also had situations where an MKV I want to watch gets identified by SageTV as a music file, but I probably need to create a separate thread for that.
Does anyone have any suggestions as to how to get Sage to put that one Frasier file in the TV\Frasier sub-folder instead of the top level?
Old 04-30-2008, 07:38 AM
If you view the detailed info screen for that file compared to another one in the same directory, what does it show as the full path to those files?
And, have you, by any chance, set up another import path that points directly to that subdirectory?
Old 04-30-2008, 07:53 AM
aperry's Avatar
Detailed info for that file shows it to be in the S:\Videos\TV\Frasier folder, like the others. The Frasier folder is not set directly as one of the import folders, just the S:\Videos folder.
Now, I do have multiple drives where I have similar structures. Specifically, I have T:\Videos and R:\Videos, both of which have a TV subfolder (with different stuff inside them). Everything seems to be working okay from what I can see except for this one Frasier episode.
Old 04-30-2008, 10:02 AM
Taddeusz Taddeusz is offline
The problem with video files showing up in music has finally been tracked down and is supposed to be fixed in the next release of SageTV.
Old 04-30-2008, 01:22 PM
Is the folder view listing import dirs separately or combined?
Try moving the file in question to a non-import dir, refresh the imports to get rid of the file's listing (make sure it isn't listed anywahere, including on the 'Titles' view), then move it back & rescan again.
Old 04-30-2008, 02:11 PM
aperry's Avatar
The folder is combined I guess (I only see one "TV" folder when I get in there even though there is a "TV" folder on all three drives).
I'll try moving the file out, rerunning the import videos, and putting it back. I'll report back with what I find.
SageTV as media center bastafidli SageTV Software 14 12-16-2007 06:47 PM
Puzzled: Sage not using 3rd tuner wvpolekat SageTV Software 2 11-15-2007 01:36 PM
SageTV V6.3.1 Beta is Available Narflex SageTV Beta Test Software 1 11-09-2007 05:17 PM
Media Center Video Thumbnails Karen0302 SageTV Software 1 10-05-2007 04:14 AM
Any way to remove TV stuff or go right to media center? philhu SageTV Software 4 11-07-2006 03:04 PM
