Old 03-14-2020, 02:31 PM
easperhe easperhe is offline
Fullscreen doesn't cover rightmost pixel
All,
I just noticed on my new LG oled65c9 HDTV that SageTVclient in fullscreen doesn't cover the rightmost pixel. So, I see a tiny sliver of the desktop on the right side of video. Any ideas how to correct this?
Old 03-14-2020, 05:05 PM
JustFred JustFred is offline
According to the SageTv User's manual, in the client: Setup -> Detailed Setup -> Multimedia -> Overscan Settings -> Adjust
Does that resolve the issue?
Old 03-14-2020, 05:52 PM
YES - thanks! I forgot about that.
Unfortunately, that didn't seem to hold after a reboot. To work around the issue for now, I've changed my desktop background to be solid black. Not ideal, but good enough for now.
Old 03-15-2020, 07:36 AM
graywolf's Avatar
graywolf graywolf is offline
Forget what in setup but there is where you set the upper left corner and lower right corner of the display area. That is probably what needs setting
Old 03-15-2020, 09:29 PM
trk2 trk2 is offline
OLED like plasma uses pixel shift to prevent burn-in. You have to set the overscan settings beyond the borders of the tv to account that the image will periodically shift.
Old 03-16-2020, 12:42 AM
That makes sense. I'll play around with that. I also did something simple and just made my desktop solid black. Not ideal but works.
Screen goes black when going to fullscreen or leaving fullscreen [RESOLVED] Chriscic SageTV Beta Test Software 8 12-02-2010 01:12 PM
STV Import: Dead Pixel Test shadeblue.com SageTV Customizations 3 06-13-2010 06:06 PM
SageMC rendering issues when switching between Fullscreen and non Fullscreen. m1abrams SageMC Custom Interface 1 05-10-2008 05:26 PM
Help..Pixel edging!!! rdefino SageTV Software 19 03-21-2007 06:16 PM
Non-square-pixel displays. stanger89 General Discussion 11 02-06-2004 10:55 AM
