Old 05-28-2010, 11:53 AM
LikeABoss LikeABoss is offline
Specific Beta version installed on the HD200?
I have been using the beta firmwares since I bought the device and would like to roll back just one update (the one that broke file sharing).
Is it possible to flash specific versions somehow?
Old 05-28-2010, 12:06 PM
The download links & links to instructions for this are in every firmware release post in the Announcement forum.
HelenWeathers's Avatar
You can find and download from here:
http://forums.freytechnologies.com/f...t=38677&page=2
Then install from a usb drive or from your server.
Instructions are here (under Option 1 (recommended): Recovery Procedure via USB Drive):
http://forums.freytechnologies.com/f...7&postcount=16
beta, flash, hd200, update
New HD200 installed - pixelation problems tvmaster2 SageTV Media Extender 1 08-11-2009 02:40 PM
Can You Assign A Specific Tuner to a HD200? lfilomeno SageTV Media Extender 10 05-07-2009 10:21 AM
"You have an old version (null) of sagemc.jar installed." Zardoz SageMC Custom Interface 3 03-10-2008 02:00 PM
Version in Help does not match what I installed? davidk21770 SageTV Beta Test Software 4 11-26-2006 02:01 PM
