Old 10-21-2009, 11:50 PM
SilentBob SilentBob is offline
Question Supported 5ghz 802.11n USB adapters?
Eventually I'm going to be running my extenders hard-wired. However, until I get around to pulling cable everywhere that I need to I was hoping that I could get by with 802.11n
So, I ordered a Ruckus 7811 (I picked this since with beamforming it kicked the ass of every other 802.11n AP out there).
However I've run into a bit of a snag. The Ruckus 7811 only supports the 5ghz band and the ENUWI-N only supports the 2.4Ghz band, so the two won't talk.
Are there any USB adapters that are compatible with the HD200 that support 5ghz 802.11n?
Old 10-22-2009, 06:37 PM
heatvent's Avatar
heatvent heatvent is offline
Wondering the same thing.
SageTV 7.0.0.23, P5Q-EM Motherboard, 2.5Ghz Quad Core, Windows 7 x64, HVR-2250, 8GB RAM, 1TB HD, 2 HD-200 Extenders
Old 10-27-2009, 08:56 AM
Protoman's Avatar
Protoman Protoman is offline
Here is a thread that identifies a potential wireless N USB adpapter, the D-Link DWA-160. http://forums.sagetv.com/forums/showthread.php?t=43437
The only downside at this time is lack of testing for the DWA-160. There are other alternatives that operate in the 5Ghz range that would work as well called ethernet bridges. The D-Link DAP-1522 is one such device and allows for multiple devices to be connected to it via ethernet cable, and connects to the router wirelessly. Linksys makes two similar devices as well, the WET610N and the WGA600N. Netgear and Belkin also make a version. I use a D-Link DWL-G730AP, which is 802.11G only, on occasion to connect my HD200 wirelessly. It is fairly stutter-free when watching HD content.
Server: ASRock Z77 Pro5-M, Intel i3-3225, 16GB RAM, 2x HVR-1800 OTA, 2x HVR-950Q OTA, 2x HD-PVR w/SPDIF (Not in use), 2x 1TB WD Black, 2TB WD Black, and Windows 7 Professional 64-bit.
- 1x HD 300
- 2x HD 200
Old 10-27-2009, 01:41 PM
fyodor fyodor is offline
If you have coax in the rooms, you might want to consider going with a MoCA (ethernet over coax) solution. It's pretty fast and reliable. If you search for "MoCA" on the forums you can see that people have had generally favorable experiences.
Another alternative would be to get an ethernet-wireless n bridge.
F
Old 12-23-2009, 09:35 PM
evilpenguin's Avatar
Just an FYI, I bought the D-Link DWA-160 for my HD200 and it works great, just a few gotchas:
1) It only seems to work on 5ghz and didn't see any of my 2.4 ghz points. Not a huge deal, but whatever. This is prolly something Sage can fix someday.
2) There are two models, Rev. A and Rev. B, and only Rev. B works in the HD200. I ordered one off Amazon and I got a Rev. A, and then I went to Office Max and they acutally had a mix of Rev. A and Rev. B. So make sure you buy it in a store and check the box.
Clients: 1xHD200 Connected to 50" TH-50PZ750U Plasma
Server : Shuttle SFF SSH55J2 w/ Win7 Home, SageTV v7, Core i3 540, 2GB RAM, 30GB SSD for OS, 1.5TB+2x1TB WDGP for Recordings, BluRay, 2xHDHR, 1xFirewire
SageTV : PlayOn, SJQ, MediaShrink, Comskip, Jetty, Web Client, BMT
Having a problem? Don't forget to include a log! (Instructions for: PlayOn For SageTV v1.5, MediaShrink)
Old 05-04-2012, 10:37 PM
Rezolution Rezolution is offline
Anyone ever figure out how to get this to work with 2.4 on the Sage HD200?
The DWA-160 Rev B sees 2.4 ghz networks when connected to any one of my PCs but only sees 5 ghz networks when connected to my HD200. I don't have any 5ghz access points
Anyone want to trade it for an Encore wireless adapter?
5ghz, 802.11n, enuwi-n, hd200, ruckus
SYBA USB to Serial Adapters losing connection jredwine2857 Hardware Support 2 03-02-2010 11:00 PM
No any supported DVB-C USB tunner (supports PayTV through CAM/CI) ??? zsozso Hardware Support 16 03-31-2009 01:10 PM
Dvico Fusion HDTV5 USB Gold Supported?? Rem Hardware Support 4 12-23-2005 05:30 PM
USB pinouts and adapters broderp Hardware Support 1 07-27-2005 09:25 AM
adaptec VideOh! USB supported in beta? mcbain Hardware Support 2 04-14-2004 12:10 PM
