Old 05-26-2016, 03:43 PM
PLUCKYHD PLUCKYHD is offline
SageTV renamer for Kodi/Plex
So after to long of time I decided to finally post my renamer I made for a couple of users. It does require SageX and BMT. It is windows only (sorry linux users ). Of note I do have one user using it for a linux sagetv installation by running from a windows pc. It doesn't have to be run from the sagetv server just from a windows pc.
I wrote a quick readme (didn't even proof read so go easy). Any issues please submit on github and I will try to keep on top of it. Not sure there are many users that will want this but figured I would share just in case.
This allows you to use sage as a backend recorder and plex/kodi for the front in. You can schedule this to run in a batch or run occasionally when you want.
PluckyHDSage2Kodi]
I do plan on sharing the source eventually as well.
Of note you can edit the xml directly or run with the cmd line switch "/settings" to edit the settings
cheers
Old 07-30-2016, 06:11 PM
SWKerr SWKerr is offline
Was looking forward to you finishing this up but I am having a problem with it.
I have not been able to get this to run.
Just using the test file with the example folders it gives me the following error in the log. I get the same error using real files and on multiple machines.
Am I missing a pre-rec or doing something stupid. (Windows 10-64)
[Header]\r\n2016-07-30 20:01:13,573 [1] INFO PluckyHDSage2Kodi.LogHandler Version #4.0.5990.27472BETA
2016-07-30 20:01:13,657 [1] INFO PluckyHDSage2Kodi.LogHandler Fetching currExt=.mpg
2016-07-30 20:01:13,657 [1] INFO PluckyHDSage2Kodi.LogHandler Total files found for=C:\testFiles\SageTVTV
1
2016-07-30 20:01:13,827 [1] ERROR PluckyHDSage2Kodi.LogHandler Error in process on file C:\testFiles\SageTVTV\test.mpg
2016-07-30 20:01:13,827 [1] ERROR PluckyHDSage2Kodi.LogHandler System.FormatException: String was not recognized as a valid Boolean.
at System.Boolean.Parse(String value)
at PluckyHDSage2Kodi.sagexHTTP.Process(String file, SageMediaObject mediaObj)
2016-07-30 20:01:13,827 [1] INFO PluckyHDSage2Kodi.LogHandler Total files found for extension .mpg = 0
2016-07-30 20:01:13,827 [1] INFO PluckyHDSage2Kodi.LogHandler Fetching currExt=.ts
2016-07-30 20:01:13,843 [1] INFO PluckyHDSage2Kodi.LogHandler Total files found for=C:\testFiles\SageTVTV
0
2016-07-30 20:01:13,843 [1] INFO PluckyHDSage2Kodi.LogHandler Total files found for extension .ts = 0
2016-07-30 20:01:13,843 [1] INFO PluckyHDSage2Kodi.LogHandler Fetching currExt=.mkv
0
2016-07-30 20:01:13,843 [1] INFO PluckyHDSage2Kodi.LogHandler Total files found for extension .mkv = 0
[Footer]\r\n
Old 07-30-2016, 09:12 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
Did you edit the xml manually or first run it with the /settings parameter?
Software: SageTV 7
Old 07-31-2016, 08:15 PM
I edited the xml manually but tired the /settings with a fresh copy of the program and get the same error.
Old 08-01-2016, 10:41 AM
Skirge01's Avatar
Could you post the xml file, please?
Software: SageTV 7
Old 08-13-2016, 08:00 AM
Need to see the XML your settings aren't right somewhere. The log states it isn't finding any files.
What is in your folder structure "C:\testFiles\SageTVTV\test.mpg"? Do you have video files there and the video files hace to be in safetv database in their current location you can't move it out of safetv because then I cant get the sage db info.
Old 10-28-2016, 09:10 PM
Flips's Avatar
Flips Flips is offline
Thanks for your help Plucky. I wasn't understanding the general usage. I was moving recordings before. Now I just ran a test after I put in one of my recording directories. I am closer, but I still get the following error, same for each file:
[Header]\r\n2016-10-28 22:06:50,018 [1] INFO  PluckyHDSage2Kodi.LogHandler Version #4.0.5990.27472BETA
2016-10-28 22:06:50,066 [1] INFO  PluckyHDSage2Kodi.LogHandler Fetching currExt=.mpg
2016-10-28 22:06:50,076 [1] INFO  PluckyHDSage2Kodi.LogHandler Total files found for=d:\sage1\
 145
2016-10-28 22:06:50,163 [1] ERROR PluckyHDSage2Kodi.LogHandler Error in process on file d:\sage1\ACharlieBrownChristmas-12744898-0.mpg
2016-10-28 22:06:50,166 [1] ERROR PluckyHDSage2Kodi.LogHandler System.FormatException: String was not recognized as a valid Boolean.
Old 10-29-2016, 08:18 AM
Skirge01's Avatar
Probably also an issue with the settings and will need to see your XML file. It's probably a simple typo, but without looking at the XML, it's impossible to say for sure.
Software: SageTV 7
Old 10-29-2016, 06:45 PM
Flips's Avatar
Thanks for taking a look. I didn't change much from the original...
<?xml version="1.0" encoding="utf-8"?>
<configuration>
  <configSections>
    <sectionGroup name="userSettings" type="System.Configuration.UserSettingsGroup, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
      <section name="PluckyHDSage2Kodi.Properties.Settings" type="System.Configuration.ClientSettingsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowExeDefinition="MachineToLocalUser" requirePermission="false" />
       </sectionGroup>
    <section name="log4net"
            type="log4net.Config.Log4NetConfigurationSectionHandler, log4net" />
  </configSections>
  <startup>
    <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0" />
  </startup>
  <log4net>
    <appender name="LogFileAppender" type="log4net.Appender.FileAppender">
      <file type="log4net.Util.PatternString" value="PluckyHDLog-%date{yyyy-MM-dd_HH-mm-ss}.log" />
      <param name="AppendToFile" value="true" />
      <layout type="log4net.Layout.PatternLayout">
        <param name="Header" value="[Header]\r\n" />
        <param name="Footer" value="[Footer]\r\n" />
        <param name="ConversionPattern" value="%d [%t] %-5p %c %m%n" />
      </layout>
    </appender>
    <appender name="ConsoleAppender" type="log4net.Appender.ConsoleAppender" >
      </layout>
    </appender>
    <root>
      <level value="INFO" />
      <appender-ref ref="LogFileAppender" />
      <appender-ref ref="ConsoleAppender" />
    </root>
  </log4net>
  <appSettings>
    <add key="ClientSettingsProvider.ServiceUri" value="" />
  </appSettings>
  <system.web>
    <membership defaultProvider="ClientAuthenticationMembershipProvider">
      <providers>
        <add name="ClientAuthenticationMembershipProvider" type="System.Web.ClientServices.Providers.ClientFormsAuthenticationMembershipProvider, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" serviceUri="" />
      </providers>
    </membership>
    <roleManager defaultProvider="ClientRoleProvider" enabled="true">
      <providers>
        <add name="ClientRoleProvider" type="System.Web.ClientServices.Providers.ClientRoleProvider, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" serviceUri="" cacheTimeout="86400" />
      </providers>
    </roleManager>
  </system.web>
  <userSettings>
    <PluckyHDSage2Kodi.Properties.Settings>
      <setting name="SageServerHttp" serializeAs="String">
        <value>http://localhost:8080</value>
      </setting>
      <setting name="DeleteAfterCopy" serializeAs="String">
        <value>False</value>
      </setting>
      <setting name="UserName" serializeAs="String">
        <value>sage</value>
      </setting>
      <setting name="Password" serializeAs="String">
        <value>frey</value>
      </setting>
      <setting name="SourceLocation" serializeAs="Xml">
        <value>
          <ArrayOfString xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
            xmlns:xsd="http://www.w3.org/2001/XMLSchema">
            <string>d:\sage1\</string>
          </ArrayOfString>
        </value>
      </setting>
      <setting name="NewLocation" serializeAs="String">
        <value>C:\TestFiles\</value>
      </setting>
      <setting name="InclArticleFiles" serializeAs="String">
        <value>True</value>
      </setting>
      <setting name="Extensions" serializeAs="Xml">
        <value>
            <string>.mpg</string>
            <string>.ts</string>
            <string>.mkv</string>
          </ArrayOfString>
        </value>
      </setting>
      <setting name="TvSubFolder" serializeAs="String">
        <value>TV</value>
      </setting>
      <setting name="MovieSubFolder" serializeAs="String">
        <value>Movies</value>
      </setting>
      <setting name="RunTestOnly" serializeAs="String">
        <value>True</value>
      </setting>
      <setting name="IgnoreDuplicateFiles" serializeAs="String">
        <value>True</value>
      </setting>
      <setting name="ScrubStartingArticlestoEnd" serializeAs="String">
        <value>True</value>
      </setting>
      <setting name="MovieFileRenamParams" serializeAs="String">
        <value>{ShowTitle} ({ShowYear}) {Resolution}-{@MediaFileID}</value>
      </setting>
      <setting name="MovieFolderRenamParams" serializeAs="String">
        <value>{ShowTitle} ({ShowYear})</value>
      </setting>
      <setting name="TVFileRenamParams" serializeAs="String">
        <value>{ShowTitle} ({ShowYear}) S{SeasonNum}-E{EpisodeNum} {EpisodeName} [{Resolution}]-{@MediaFileID}</value>
      </setting>
      <setting name="TVFolderRenamParams" serializeAs="String">
      </setting>
      <setting name="DeleteLowerResolutionOnReplacement" serializeAs="String">
      </setting>
      <setting name="UseResolutionNames" serializeAs="String">
      </setting>
      <setting name="ResolutionOrder" serializeAs="String">
        <value>1080p:720p:480p:480i</value>
      </setting>
      <setting name="ResolutionNames" serializeAs="String">
        <value>Bluray:HDTV:DVD:NTSC</value>
      </setting>
      <setting name="ArticleExtensions" serializeAs="Xml">
        <value>
            <string>.edl</string>
            <string>.properties</string>
            <string>.jpeg</string>
          </ArrayOfString>
        </value>
      </setting>
      <setting name="DuplicateAdder" serializeAs="String">
        <value>[duplicate]</value>
      </setting>
      <setting name="MoveDuplicatesToSpecialFolder" serializeAs="String">
        <value>True</value>
      </setting>
      <setting name="DuplicatesFolder" serializeAs="String">
        <value>Duplicates</value>
      </setting>
      <setting name="RenameMultiSegments" serializeAs="String">
      </setting>
      <setting name="NewNameForDuplicates" serializeAs="String">
        <value>True</value>
      </setting>
    </PluckyHDSage2Kodi.Properties.Settings>
  </userSettings>
</configuration>
Old 10-29-2016, 07:58 PM
 145
That's an odd is there 145 files in there? I can see what file it's failing on that file is in sage database currently correctly? It's obviously a bad check by me. Let me pull up the source code in the next day or two and see if I can help you out. It may be a configuration error I'll look over that log you posted as well. I know this works because I use it
Old 10-31-2016, 03:41 PM
Flips's Avatar
Yep, there are 145 files in that directory. I get the same error on every file, here is the last file and the last few lines of the log:
2016-10-29 19:43:15,110 [1] ERROR PluckyHDSage2Kodi.LogHandler Error in process on file d:\sage1\WisconsinFoodie-WildTomatoIslandOrchardCider-14266633-0.mpg
2016-10-29 19:43:15,111 [1] ERROR PluckyHDSage2Kodi.LogHandler System.FormatException: String was not recognized as a valid Boolean.
2016-10-29 19:43:15,113 [1] INFO  PluckyHDSage2Kodi.LogHandler Total files found for extension .mpg = 0
2016-10-29 19:43:15,113 [1] INFO  PluckyHDSage2Kodi.LogHandler Fetching currExt=.ts
2016-10-29 19:43:15,126 [1] INFO  PluckyHDSage2Kodi.LogHandler Total files found for=d:\sage1\
 0
2016-10-29 19:43:15,126 [1] INFO  PluckyHDSage2Kodi.LogHandler Total files found for extension .ts = 0
2016-10-29 19:43:15,127 [1] INFO  PluckyHDSage2Kodi.LogHandler Fetching currExt=.mkv
2016-10-29 19:43:15,139 [1] INFO  PluckyHDSage2Kodi.LogHandler Total files found for=d:\sage1\
 0
2016-10-29 19:43:15,139 [1] INFO  PluckyHDSage2Kodi.LogHandler Total files found for extension .mkv = 0
[Footer]\r\n
What is the call that you make to the webserver? I can try that manually to make sure that is working. If I change the server or the directly slightly it will error out, so I believe it is hitting the server, but maybe it isn't returning something properly. Only the BMIT site is used on the web server?
flips
Old 10-31-2016, 04:12 PM
iRRC I log it if it doesn't hit the sagetv server. Do you have sagex remote services installed?
Old 10-31-2016, 08:33 PM
Flips's Avatar
Yep, double checked tonight.
Are you pulling out the sageid from the filename or are you passing the filename to the api?
Poking around in the api, this worked:
http://localhost:8080/sagex/media/thumbnail?mediafile=12744898
But this didn't... but I'm not sure it was supposed to...
http://localhost:8080/sagex/media/thumbnail?mediafile=ACharlieBrownChristmas-12744898-0.mpg
or did my 145 files break the array or something?
flips
Old 11-02-2016, 07:47 AM
Are you running v9 or v7 apparently something broke in 9 I just found out. Not sure what it is yet but working on it.
Old 11-02-2016, 12:21 PM
Flips's Avatar
Yep I'm on v9...
Thanks for looking into it! Let me know if there is anything I can do to help.
flips
The "Best" of stock SageTV and Kodi, can it be done? stanger89 Gemstone for v7 21 06-24-2016 03:08 PM
Kodi 17 and Nexus Player.. SageTV nyplayer General Discussion 5 03-14-2016 10:47 AM
Kodi as SageTV Alternative ? PeteCress General Discussion 23 03-04-2016 08:48 AM
Plex 4.0 - better peruse the Plex.forum before updating.... tvmaster2 General Discussion 18 08-17-2015 10:16 AM
Eventghost, Plex and SageTV lovingHDTV SageTV Software 16 09-18-2014 09:04 PM
