Old 11-08-2019, 10:23 AM
tmiranda's Avatar
tmiranda tmiranda is offline
SageTV Server on a NAS
I've been thinking about how to simplify my Sage server. I have always used a fairly large PC capable of holding multiple drives. In the past I had a smaller form factor PC with the recording drives on a NAS and while this worked there were sometimes performance issues under heavy load. It dawned on me that having the server software running on a NAS would be an ideal solution.
I know unRaid is available but that's essentially the same (in my mind) as running the server on a PC.
Are there any NASs out there capable of running SageTV? Do any of them support Java applications?
maybe I'm barking up the wrong tree and I should just go the unRaid route. I just have had such good experiences with ReadyNAS (a low-end NAS) that I'd love to see Sage run on a simple box like this. The thing is small, quiet, cheap, easy to configure, has zero maintenance, and is very reliable. Everything I want from my SageTV server.
Old 11-08-2019, 10:28 AM
jusjoken jusjoken is offline
I use an older QNAP with 6 drive bays and boot it with unraid. Works great and i seldom have any issues. It quietly just runs.
k
Old 11-08-2019, 01:15 PM
tmiranda's Avatar
k
So unRaid is the OS on the box? Does it support the Sage docker?
Old 11-08-2019, 06:03 PM
gclayto's Avatar
gclayto gclayto is offline
I've been running my Sage docker on a Synology DS218+ with no problems. The price and performance with this configuration are hard to beat.
Old 11-08-2019, 10:07 PM
tvmaster2's Avatar
I have little idea what any of you are saying, but it sounds very intriguing - a quiet, low-power NAS for Sage. I shall keep reading this thread
Old 11-09-2019, 05:16 AM
No QNAP have their own OS but i set it to boot from USB and boot from unraid instead which supports docker and all unraid features.
k
Old 11-09-2019, 06:27 AM
tmiranda's Avatar
Cool. How good is the CPU? Can it handle real time transcoding?
Old 11-09-2019, 06:28 AM
tmiranda's Avatar
k
Got it. Thanks.
Old 11-09-2019, 07:20 AM
gclayto's Avatar
The DS218+ has hardware decoding capabilities and can handle 4k. Here is the spec from their website.
CPU Model Intel Celeron J3355
CPU Architecture 64-bit
CPU Frequency Dual Core 2.0 (base) / 2.5 (burst) GHz
Hardware Encryption Engine (AES-NI)
Hardware Transcoding Engine H.264 (AVC), H.265 (HEVC), MPEG-2 and VC-1; maximum resolution: 4K (4096 x 2160); maximum frame rate per second (FPS): 30
In real-world use, it just works. I haven't noticed any performance differences between the DS218+ and my old PC server running Windows7 with an AMD fx8350 8core. Except for its quieter and uses much less power.
When I first started using it I monitored the CPU performance closely, I never saw it run much above a 50% load. I'm running a couple of Dockers on the DS218+ and use it to back up my windows boxes. It has more than enough horsepower to run Sagetv.
The price is the best part with a 4Tb Raid 1 and 4Gb of memory I have less than $400 invested.
Old 11-09-2019, 11:11 AM
tmiranda's Avatar
Good info. Thanks. I have been doing some reading and it seems like a good way to go. I am currently using a machine that I built but it is way overkill.
Old 11-09-2019, 09:14 PM
SteveW's Avatar
SteveW SteveW is offline
I just bought a 1019+ and have been wondering about doing this... I run two HD-PVRs tho - they connect to my Sage server by USB so... think I would be stuck with a Win box with SageTV anyways as at least an encoder.
Server: Win 10 Pro 64 Bit, Intel i5, 8 GB, Samsung EVO 850 500 GB for OS, WD Black 4 TB + WD Black 1 TB for Recordings, WD Green 2 TB x 1 and WD Red 6 TB x 2 for DVD/Bluray Rips, Music, Home Movies, etc., Sage 9.1.8.770, HDPVR x 2, BellTV 6131 Receiver x 2, USB-UIRT with 56 KHz Receiver
Clients: PC Client x 2, HD-300 x 4 (1 Using Netgear MoCA Coax Bridges), Placeshifter x 1
Old 11-10-2019, 07:17 AM
Black Friday is upon us. A Silicon Dust HDHR is a much better tuner solution for a NAS. Is it possible to install the HDHR drivers into a docker image?
Old 11-10-2019, 07:22 AM
gclayto's Avatar
SageTV just finds the HDHomerun on the network. Select them as a video source, set up and go.
Old 11-10-2019, 09:37 AM
EnterNoEscape's Avatar
This would be the same case for OpenDCT (on Linux and Windows). They just use a proprietary communication protocol, so the drivers aren't really needed to discover and use them. Under Windows, the drivers are only needed because SageTV chooses to only talk to it via the BDA drivers.
Old 11-10-2019, 10:35 PM
tvmaster2's Avatar
only if you live 35 miles from a transmission site, unless there’s a cable-card HDHR?
Old 11-10-2019, 11:08 PM
jpwegas jpwegas is offline
The HDHR Prime (HDHR3-CC) is a 3 tuner cable card tuner, but it's not likely available in any Black Friday deals as the stock of them seems to be exhausted. Guessing production was stopped last year due to the expected (but long delayed) 6 tuner cable card version.
--John
Old 11-13-2019, 12:26 PM
It might be overkill for just SageTV but once you get unRAID installed and realize that testing out things like Plex, Emby, Jellyfin, Sonarr, Radarr, etc, all become just a click away, you might just end up with a machine that is running 10+ docker containers + windows VMs (as I am).
Old 11-14-2019, 05:48 AM
tmiranda's Avatar
I have debated unRAID for some time. My current linux server has several drives, some EXT3 and some Windows formatted. Can I try unRAID on this system without reformatting the drives?
Old 11-16-2019, 08:12 PM
alfi33 alfi33 is offline
unRAID is installed and boots off a USB flash drive. So you'll need that plus at least 1 drive (that unRAID will format) to try is out.
It really is a great multi-purpose home server. Definitely one of the easiest ways I've seen to run Docker containers.
Server: SageTV v9 on unRAID Docker; i5-2400; 16GB RAM; 9TB storage array; SiliconDust HDHR3
Client: Windows10; Intel Core2Duo; 4GB RAM; NVIDIA GeForce GT 1030
Client: NVIDIA ShieldTV
Client: Fire TV Stick 4K
Old 11-19-2019, 01:26 PM
As alfi33 said, it boots from USB and require only 1 drive. So, to try it out, it can be pretty risk free. I would, however, disconnect all drives except for 1 drive that you want to play with for unraid, that way you don't accidentally destroy your good data drives by accident. From an investment point of view, I think you can try unraid for free, and then the license is a 1 time $60 license (I think -- been awhile, but, it's not expense)
Anybody running SageTV server and Plex server on the same machine? MickBurke SageTV Software 14 08-25-2016 10:24 PM
Connection options between storage server and SageTV server? Konig Hardware Support 18 02-22-2011 05:49 PM
Combining HomeSeer server and SageTV Server simonk1969 Hardware Support 1 11-23-2009 02:16 PM
How Does SageTV Media Server for Windows Home Server work? PhillTheChill SageTV Software 7 11-16-2007 01:46 PM
Samba Server went down for 60 minutes, files still on server, not in SageTV? perfessor101 SageTV Software 2 04-13-2006 12:18 PM
