Closed Thread
Old 02-28-2008, 06:07 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Thumbs up SageTV V6.3.10 Release Candidate
Howdy,
We've got an updated build of V6.3 for Windows & Linux that fixes quite a few issues in V6.3.9.
We should be at the end of the V6.3 fixing for Windows/Linux now. Macintosh is still a little behind; but it should be going back into beta any day now.
As always, submit bugs to http://sagetv.com/bugs.html
Here's the links:
SageTV for Windows
http://download.sage.tv/SageTV_V6_3_10Setup.exe
SageTVClient for Windows
http://download.sage.tv/SageTVClient_V6_3_10Setup.exe
SageTVPlaceshifter for Windows
http://download.sage.tv/SageTVPlaces..._3_10Setup.exe
SageTV for Windows Home Server
http://download.sage.tv/SageTV_V6_3_10Setup-WHS.msi
SageTV Media Center for Macintosh
pending
SageTV Client for Macintosh
pending
SageTV Placeshifter for Macintosh
pending
SageTV Media Center for Linux
http://download.sage.tv/linuxbeta/server_6.3.10.tar.gz
SageTV Placeshifter for Linux
http://download.sage.tv/linuxbeta/mi..._6.3.10.tar.gz
SageTV Media Center for Linux - Debian Package Installer
http://download.sage.tv/linuxbeta/sa....3.10_i386.deb
SageTV Placeshifter for Linux - Debian Package Installer
And here's the detailed release notes for you all since the V6.3.5 release:
SageTV V6.3.10 Release Candidate 2/28/2008
Core Updates
1. Fixed bug where we no longer extracted MOV/MP4 metadata
2. Fixed infinite loop when parsing 'EA' files
3. Fixed regression bug where we were clearing the initial PTS for MPEG files
4. Added support for setting the transcode file type target to be 'wmv' (this'll still create an 'ASF' file, but it'll use the .wmv file extension which is what the Zune wants)
5. Fixed bug where multiple AC3 audio tracks would sometimes cause the wrong audio track to be selected for the transcoder
6. Added process monitoring to prevent thumbnail generator & format detector from getting out of control
7. Fixed bug in SageTVPlayer where frame steps wouldn't wait for proper completion before continuing
8. Fixed crash bug related to releasing the wrong index for a raw image when performing a scaling operation on it
9. Fixed rounding error w/ slide in/out animations. This was visible on the extender/placeshifter when the thumbnails would scroll for a whole row one item at a time.
10. Don't allow the placeshifter, extender, or client servers to launch before the complete core has been initialized on the server
11. Fixed deadlock that can occur if you shutdown SageTV while a recording is ending at just the right time
12. Fixed bug with duplicate imports of the same file. The import process now checks the database's file path index to ensure something wasn't added asynchronoulsy during the import process.
13. Removed usage of 'make_all_mediafiles_local' property (it now behaves as if it was always set at true)
14. Fixed bug where if the top/bottom scaling insets were bigger than the height we wouldn't check the left/right scaling insets to see if they were bigger than the width
15. Fixed bug where the left or right side of centered text was truncated by a pixel sometimes when rendered on the extender or in the placeshifter
16. Fixed rare layout floating point rounding error that would cause UI elements to sometimes shift when using anything but 3D rendering
17. Optimized format detection code so we don't try to use our MPEG detector on Quicktime/MP4 files.
18. FIX: HDHR missing channel 1 on channel scanning on ATSC, as we skip channel 1 ATSC as some of tuner has a problem.
19. FIX: EPG data parser dosen't terminate string properly causing Java EPG code trouble ( memory leaking, or crash ).
20. Fixed bug where we didn't scale an image with source height of 2 properly
Extender Updates
1. Fixed bug when transcoding files with an unsupported audio format so that it'll still do the video at least
2. Enhancement: Switch back to the default resolution when done playing back content in native resolution mode
Windows Updates
1. Fixed bug where the Sonic Cinemaster decoders sometimes wouldn't show up in the list
2. Added back dynamic audio pin support, because of missing some audio channel pin
3. Fixed bug where the SageTV application wouldn't wait for the service to start if the service control database was locked for some reason.
Placeshifter Updates
1. Improved responsiveness of UI while watching video w/ the Placeshifter by using the 'yield decoder lock' technique
2. When doing the bandwidth detection calculation; set our thread to highest priority so we don't get interrupted during the sending
3. Fixed bug with infinite CPU usage when using the customize command in a remote placeshifter that already had the Studio open on the server
4. Get OpenGL context when uploading image outside of frame drawing.
Studio Updates
1. Internally synchronized usage of EnsureVisibiltyForValue and SetFocusByValue so that they don't cause accidental UI corruption when invoked asynchronously
2. Fixed bug where loading a binary STV file with dangling references (legacy bug) wouldn't work
STV Updates
1. When playing a group of videos/recordings, ask whether to play all or just the ones not yet watched.
2. Treat Smooth FF/REW as page right/left & FF2/REW2 as jump # days in Program Guide.
3. Search menu jumps to Google video search after choosing to search Online Videos.
4. If an online video feed has no title, show the feed's property name instead of a blank button.
5. Changed Watched command for DVDs to only clear its watched status.
6. Fixed video folder browser view to handle DVDs that don't use the VIDOE_TS subfolder.
7. Online media content uses a marker to indicate if an item is audio-only.
8. Added several PBS online video feeds.
SageTV V6.3.9 Release Candidate 2/13/2008
Core Updates
1. Fixed bug parsing the hour of the day for DVB EPG data streams using UTC time format
2. Fixed rare bug when users would get an EOF exception connecting to EPG server
3. Fixed bug where the commands being sent to SageTVPlayer were not always serialized in the proper order
4. Only reinitialize the metadata for a MediaFile if it has an external Show ID starting with 'MF'. That indicates it was generated internally by SageTV; otherwise it'll end up overwriting data injected by the STV layer.
5. Crop out the top 8 pixels of an image when generating a thumbnail so we don't a line from VBI distortion
6. Increased time difference required to be seen in a file's timestamp in order to think it's different (the new diff is 2.5 seconds; this is because FAT file systems only have 2 second accuracy on file modification timestamps)
7. Fixed regression bug where SageTVClient would try to start a MediaServer
8. Fixed bug where TV recordings might be removed from a drive that goes offline temporarily
9. Added support for 'advanced_video_file_recovery' for imported files (music, video, pictures)
10. Fixed bug where we wouldn't append a file extension to a transcoded file if it had a dot anywhere in the filename
11. Added support for Apple Lossless Audio files (ALAC) on SageTV, Placeshifter and the extenders
12. Fixed bug where at the end of an audio podcast we'd start playing music from the library if random music playback was enabled
13. Fixed issue with misaligned Y coordinate for text that was restricted in its front shrinkage
14. Fixed bug in parsing of album art for AAC and WMA files
15. Fix:write DVB-C channel wrong name into frq file
16. Fix: load PredefinedQAM.frq file bug, QAM user use it to speed up qam scanning
17. Fixed bug where it would return failure when the DirecTV receiver just couldn't receive the channel that we attempted to tune
Extender Updates
1. Added proper synchronization for when the MiniDVDPlayer is closed
2. Fixed bug where transcoded audio files would no longer playback on the MVP
Windows Updates
1. FIX: HDHomeRun 5 min recording missing
2. Fix: DVB crash bug in 6.3.8RC
3. Fix a regression bug that has a trouble for mutiple audio track stream PTS fixing
4. Fix a regresson bug on support Twian card
Linux Updates
1. Fixed HDHR capture bug on Linux
Studio Updates
1. Fixed bug in animation system where multiple dual surface animations would sometimes cause some of the dual surface animations not to render even though they all used the same Layer
2. Optimzed MediaFile GetSize() call so it doesn't do isDirectory() on the file; it just checks the DVD bit since that's the only reason it would be a folder
3. Fixed bug where Keystroke API call didn't send proper key characters for non-printing characters
4. Added Utility API calls: DeleteFilePath and RenameFilePath
STV Updates
1. Added ability to save fully downloaded media files to the import library, using the Record command or menu option during playback. Video files go to the video lib; audio feeds go to the music lib.
2. Fixed the name of the ui/min_allowed_shrunk_font_size property used in the STV.
3. Modified slide out animations to delay a short time before using "unease" when sliding out.
4. Modified screen saver photo transition to fix fade out of previous image.
5. Fixed position of the direction arrow when scrolling through images in the photo viewer.
6. Fixed overscan area's black fill in photo viewer, in order to clear that area's previous content.
7. Added ability for user to add custom Online Services content w/o affecting the default content list, using custom online video properties files.
8. Fixed another location where the "getting ready for playback" dialog can get stuck open if the parental control code is not entered correctly. Also fixed Parental code request to not return until after the "wrong code" message has been dismissed.
9. Added ability to use Play command while viewing the Song Detail screen.
10. Modified point of determination for whether live TV is being watched in the playback menu.
11. Fixed line at edge of the screen in the photo viewer.
12. Added several more online video feeds.
13. Fixed bug where setting the clock back a significant amount could disable the weather update for awhile
14. Optimized sorting of folder/file lists in the STV
SageTV V6.3.8 Release Candidate 1/31/2008
Core Updates
1. Added support for multi-channel Favorites
2. Fixed NPE when playing back a file with an undefined video format
3. Fixed bug where transcoding a file with PCM audio into an MPEG4 format would use an incorrect audio bitrate
4. Added properties xcode_process_priority_offline and xcode_process_priority_streaming which control process priority for the transcoder on Windows when in offline or streaming modes
5. Fixed a bug where thumbnail generation on a currently recording file could hang forever causing no more thumbnails to be generated
6. Fixed bug where we'd still try to get a thumbnail from an MPEG2-TS file if it was a TV recording using an offset time (it was already fixed for non-TV recordings)
7. Removed the requirement that each DVD had to have all of its files in a VIDEO_TS subfolder (they all still need to be in the same folder though)
8. Completed support for bi-directional text rendering on the media extenders and in 3D mode. It now requires setting the property "ui/load_complete_glyph_maps=true" in order to function.
9. Fixed bug where we'd restart the transcoder incorrectly if we seeked to the end and then back to the beginning
10. Fixed bug where some nested duplicate surface usage would cause some animations to render improperly
11. Added new property "advanced_video_file_recovery" which if set to true will cause SageTV to do a more thorough analysis on newly found video files in the video storage directories in an attempt to re-correlate them with existing recordings (great for when you move your files to a new storage directory or move an install to a new machine)
12. Fixed bug so we select the right media player when playing back FLV files with the VP6 codec
13. Fixed bug with animations on re-use of components within a table
14. Added property 'ui/min_allowed_shrunk_font_size' which specifies the minimum size that 'shrink to fit' text should be shrunk to
15. Fixed bug where Page Left & Page Right didn't work on scrollable panels if they were all the way right or left respectively.
16. Fixed issue where animations on surfaces that had a transparency value didn't render properly
17. Fix: a parsing error on DVB-S region and satelittle name string that is passed in from sage.properties
18. Fix: format detection missing in MPEG1 format.
19. Add genre support for DVB stream embedded EPG.
20. Add a code to handle the ripped TS stream that has a PAT/PMT at begining of stream/file
21. Fix a "No Signal" bug that is caused by missing the main audio track in auido detection.
Extender Updates
1. Fixed crash bug on the STX-HD100 where it would try to render a rectangle of zero height
2. Fixed bug on HD media extender where doing a smooth rewind to the beginning of a file would never actually stop by itself
3. Fixed bug where we'd use pull mode when trying to placeshift anything but MPEG2-PS to the extender
4. Fixed smooth FF/REW on the HD media extender so that resuming of playback will occur from where the smooth FF/REW was ended and not up to 30 seconds further in the stream which is where the buffering was at.
5. FIX: a rebuilt PMT bug for play back saved TS stream by third party into HD extender
Windows Updates
1. Updated to newest version of the MPEG Audio/Video Encoder/Decoder DirectShow filters on Windows
2. If we have an error rendering a texture in DX9 then remove that texture so it'll be re-created properly
3. Fixed bug on Windows where other applications couldn't use the 3D system if SageTV was in full screen exclusive mode and then put into the system tray without first playing back video
4. Add preferred media support in TSSplitter for upstream filter to query.
5. Allow PMT rebuilt in TSSplitter that is controlled by registry RebuildPMTEnabled(DWORD)
6. FIX: stuttering HDHR recording in PS format recording
7. Allow a third party to create a push filter that appears in DirectX of "Video Capture Source/BDA Source Filters/BDA Receiver Component" to feed in TS stream directly into sagetv, such as Firewire USB capture.
Studio Updates
1. Added an 'Unease' animation option which will do an ease out instead of in (and vice versa) for In/Out animation operations
2. Added 'Unclipped' animation option which is used with the 'Slide' aniimations so the same motion is achieved but with no clipping
3. Added new 'Behind' suffix as another animation option. This'll cause animated surfaces to show up behind others where normally they would be on top (such as in any 'out' animation)
4. Fixed bug where the NumHPages & NumVPages variables weren't always being set correctly for scrolling panels
STV Updates
1. Converted SageTV Recordings and the music, photo, and video browsers to use the core animation system for grouped item thumbnail transitions .
2. Added transitions for groups in row mode for SageTV Recordings.
3. Converted slideshow/photo viewer to use core animations for photo transitions.
4. The music info shown on the playback menu moves via core animation.
5. Converted screen saver to use animation system for state transitions: logo, photos, and music info.
6. Moved Animation Options to the General section of Detailed Setup.
7. Fixed download of mp3 online content when the duration was not specified in the feed data.
8. Increased size of thumbnail for single item buttons (non-grouped items).
9. Added option in Detailed Setup -> Customize to set the minimum font size.
10. Updated Favorites Manager for multi-channel Favorites.
SageTV V6.3.7 Release Candidate 1/22/2008
Core Updates
1. Add Switzerland DVBC frequency entries.
2. Fixed bug where animations in nested surfaces was falsely detected if there was another nested surface behind it (fixed scrolling animation issue in limit Fav by day setting)
3. Added SageTV recording recovery for .mkv files
4. Fixed bug where parental controls dialog wouldn't come up on remote placeshifter clients (actual bug was global hook cache wasn't cleared when switching STVs)
5. Fixed bug where we'd detect MPEG1-PS files as MPEG2-PS
6. Fix: ATSC tune to wrong channel with tuning string "channel-0-minor" (major = 0)
7. Fix: DVB channel scan return no channel found.
8. Fix: MPEG1 recording duartion dectection bug.
9. Fix: a aspect ratio format dection bug for the 1:1 ratio mpeg2 recording.
Extender Updates
1. Fixed smooth FF/REW for HD files on the STX-HD100 so that it matches the desired rate much better
2. Changed behavior of property 'ui/enable_hardware_scaling_cache' so that it makes image loading on the STX-HD100 behave like the MediaMVP (but this will negatively impact performance of the extender so this is not on by default). This will resolve users issues with large custom thumbnails.
3. Fixed bug on STX-HD100 where clipped non-filled rectangles wouldn't render
4. Moved default advanced aspect ratio to be in the client's properties; not the server's (also fixed support for this property)
5. Fixed support for AVI, MP4, MKV and ASF files that dont' have native codec support on the HD extender so that the server will transcode them (such as MJPEG and WMV8)
Placeshifter updates
1. Fixed playback of MKV files on a local network
Windows Updates
1. Added support for KWorld DVB-T USB 339U (AF9015 DVB) dual tuner
2. Added support for KWORD DVB-T PCI 160 (dual tuner)
3. Fixed bug where the video wouldn't be visible after changing channels sometimes until an OSD refresh when using VMR9
4. Don't try to generate thumbnails for files recorded with the ConvertX because the thumbnail generator can't parse the MPEG2 format used by those recordings
5. Fix: new SageTV software Video encoder wrong aspect ratio
6. Fix Broken code for old HDHR BDA driver support
7. Updated bundled JRE installer to the latest 1.6.0_04
Studio Updates
1. Don't report animations as being supported if the rendering device doesn't support it (it used to just rely on the property's value)
2. Only let animations target components in the top options menu of the UI if an options menu is visible
3. Added interruptable animation support (through an optional parameter to AnimateVariable, AnimateTransition and AnimateDelayed)
4. Fixed bug where full screen BG layer 'out' animations didn't work if an 'in' animation for the BG layer was happening at the same time
STV Updates
1. Look for "background.jpg" themed BG image instead of "Background.jpg", so the file can be found on a case sensitive OS.
2. The videoframe/always_call_fileplaybackfinished property is always reset to false since some custom STVs always set it to true.
3. Fixed calls where ChannelSet() was using GetPhysicalChannelNumberForLineup() instead of GetChannelNumberForLineup().
4. Removed BG for color calibration screen.
5. Fixed several places where the focus indicator was on top of the button text.
SageTV V6.3.6 Release Candidate 1/4/2008
Core Updates
1. Repair the video directory property of MediaFiles since it could be wrong if they moved directories
2. Added retry for when the MiniServer socket fails to open at startup
3. Added property: ui/load_complete_glyph_maps which enables complete characters in 3D mode and on the MVP & STX-HD100
4. Added retry for when the SageTVServer socket fails to open at startup
5. Fixed bug so files with .mp4 file extensions get auto-recovered by the importer (before it only did .mpg, .ts and .avi)
6. FIX: the TS recording created by third party software isn't able playback in SageTV
7. Add H.264 format detection for H.264 remuxed PS file.
Extender Updates
1. Added optimized seeking for MPEG2-TS file playback on media extenders (same technique used with MPEG2-PS files and the media extenders)
2. Fixed bug on HD extender where it wouldn't enter screen saver mode sometimes
3. Added UI specific property: default_advanced_aspect_ratio which allows setting the default aspect ratio on the STX-HD100
4. Fixed bug on extender playback where the volume would get reset to the maximum if there was a failure playing back a file.
5. Increased buffer sizes in remuxer so we don't overwrite data we've already converted
6. Fix missing audio on some DVD. Force sync on interleaved block.
Windows Updates
1. Fixed so that the 'always_use_dshow_player' property also affects music playback as well
2. Ues a temporary walk around way for a M780 bug that recording file is locked, and resource isn't released.
Macintosh Updates
1. Fixed fullscreen mode on Leopard
2. Added mouse hiding
3. Fixed placeshifter not being able to resume video due to an exception in the VM not being cleared or handled
4. Added support for Pinnacle PCTV Hybrid 800e
5. Now properly causes the app to rescan for devices on hotplug events
1. Added property "miniplayer/min_bandwidth_for_no_transcode" which allows setting the bandwidth that must be detected in order to the auto-transcoder not to kick in
STV Updates
1. Reset last thumb scroll time for a folder when the item gains focus so that it doesn't scroll its thumbs immediately.
2. Changed YouTube "Top Viewed" and "Recently Added" categories to "Most Viewed" and "Most Recent".
3. Added "Top Channels" to the YouTube video menu.
4. During playback of a live recording, Detailed Info now jumps to Recording Details instead of Program Info.
5. Changed copyright notice on System Info screen to say "2008".
6. Added some more online video links
Jeffrey Kardatzke
Google
Founder of SageTV
Closed Thread
SageTV V6.2.8 Release Candidate is Here! Narflex SageTV Beta Test Software 1 09-17-2007 09:01 PM
SageTV V6.2.6 Release Candidate is Ready! Narflex SageTV Beta Test Software 3 08-25-2007 11:00 PM
SageTV V4.1.14 Release Candidate Is Available Narflex SageTV Beta Test Software 98 04-24-2006 06:59 PM
