Old 09-03-2009, 04:44 PM
WalterCleeson WalterCleeson is offline
Comskip setup
New forum member, but long time sagetv user and forum lurker.
I am doing a completely fresh setup of a sage server and clients. 6.6.2
It's been a while and although have read many posts here on comskip I am still a bit confused by what goes where.
All of my recordings are stored on the sage server in a shared directory. Sage servers path to recordings is via UNC. The server is an XP Pro machine and is part of my home domain.
I want to install comskip monitor on the server to create the comskip files for use when viewing by sage clients on two other PCs.
Do I need to install JUST the comskip monitor v2.7 on the server or also comskip80_025 on the server?
On the clients, what do I need to install besides importing the comskip playback.stvi? Do I also need to install comskip80_025 or does the playback use the comskip.exe on the server?
Sorry for being dense. I did try to figure this out before posting. I read the setup on at http://www.geektonic.com/2008/02/ski...of-button.html
but after doing it that way (it seemed to imply you don't need a separate comskip.exe on the client becuase it never said to install it) any time I tried to run a manual commercial detect from the client on a recording I got a failure message, which I assumed was because it could not find the comskip.exe
I just need a nudge in the right direction. Thanks
Walter
Old 09-03-2009, 04:58 PM
You need both Comskip monitor and comskip80_025 Monitor does what it says-it just looks for new files. WHen it sees one it kicks off comskip.exe
Just install the STVI at each client. (For the default interface.)
Walter
Answers in green above. (and below.)
Do not try to use any (or most) of those types of commands. Those are legacy commands left over from before the monitoring programs. (If you want to use those then yes, you would need to put comskip.exe in the same folder as sagetv.exe, I believe.
Old 09-04-2009, 07:18 AM
Thanks Gerry. It all seems to be working fine now.
-Walter
client, comskip, install, setup
Comskip Monitor setup help ryansebiz SageTV Customizations 4 02-25-2009 08:16 PM
Sanity check my server setup (WHS, ComSkip, HD) brianblank Hardware Support 0 07-19-2008 10:35 PM
Getting Comskip Setup Athfar SageTV Customizations 7 12-13-2007 11:18 AM
Comskip setup question on Client phunny SageTV Customizations 12 07-29-2007 08:19 PM
Please help me setup Comskip with SageTV Ansy_74 SageTV Customizations 3 02-02-2007 01:47 PM
