Old 05-08-2006, 02:27 AM
Polypro Polypro is offline
Dynamic Menu Icons
I know this is mentioned in the help/faq, but I just got around to implementing this and it's pretty cool. If you open menu.xml, for each (or most) entries, there is a link to the folder where the icons should be placed, and their name. I created the dynamic_menu_icons folder where menu.xml was looking for it and inside placed the icons with the name menu.xml was looking for (Or you can change the path). I downloaded a bunch of skins from the Media Portal and XLobby sites and used some beautiful looking transparent .pngs. Thanks to those people and thanks neilm!
P
Old 05-22-2006, 12:45 AM
BruenerXII's Avatar
BruenerXII BruenerXII is offline
P
Polypro Thanks man!
I must have missed that in the faq because it is the $#@!
So easy to implement even i could do it.
I checked out Media Portal and XLobby and as you did and downloaded some skins, borrowed a few icons. Props to whoever made these little blue doods. (they are in so many skins i figured it would be ok to use them myself)
I dont understand why Sage doesn't come with some sort of icons by default, because they are an awesome addition and make my Sage Media Center much more unique.
Here's a Screenshot of my SageTV main menu with the little blue dood icons!
Old 05-22-2006, 12:52 PM
cmaffia's Avatar
cmaffia cmaffia is offline
Send a message via Yahoo to cmaffia
I believe the Sage default stv is so bare by design in order to allow us to deviate dramatically from it. In the end it allow us to each have very unique experience. Having these things in core would take the fun out of customizing.
Server: Dual Tuner: PVR-150MCE/PVR-250MCE/SageTV v5.02/Asus Pundit-R 2.4GHZ/512MB DDR RAM/250 GB Maxtor HD (8MB Buffer) External Seagate 400GB HD via USB 2.0/Onboard ATI 9100 using SVIDEO TV-Out/Nvidia DVD decoder/Actisys 200L IR Blaster (Dish receiver) USBUIRT (DirectTV receiver)/Lite-On 4X DVD-R/RW/Windows XP Pro SP2/Adesso Mini IR Keyboard w/integrated mouse/Tivo "Peanut" Remote via USBUIRT/Dish Network Model 301/DirectTV subscriber/Webserver Plugin v2.8
