Old 11-24-2010, 01:59 PM
Oddity Oddity is offline
HD Theater 300 Power Supply
I live in the UK and have just purchased one of these units and as I believe the power block is directly attached to the mains plug pins, I'm looking to buy a power adapter with a UK specification three pin plug. I know that I need a 12v 2amp unit where the outer rin is +ve, but can anyone tell me what the output plug size that goes into the HD theater is?
I don't want to use a travel adapter to convert the supplied unit, thanks for any help in advance.
Old 11-30-2010, 07:07 PM
Nelbert Nelbert is offline
The plug i'm using on the maplin psu is the following dimensions:
5.5mm outside
2.5mm inside
12mm length
The HD300 PSU is Centre positive: ie tip = +ve not ring
Maplin are currently have a multi-adapter (notebook style with detachable mains lead) for 20 instead of 35, it's a 60W switchmode AC->DC with 8 switchable polarity adapter plugs.
Old 12-01-2010, 06:50 AM
Bagal Bagal is offline
I purchased one of these http://cpc.farnell.com/sunfone/acw02...09?Ntt=sunfone which seems to work just fine
Old 12-06-2010, 01:13 PM
thanks for the info
ordered from cpc and all working fine.
Power supply drowned! radiopaque SageTV Media Extender 4 11-17-2010 01:09 PM
HD PVR power supply Fingergottes Hardware Support 1 09-22-2008 01:13 PM
HD Homerun Power Supply Eckwell Hardware Support 12 09-10-2008 08:28 AM
Silent/80 Plus power supply? morikaweb Hardware Support 12 02-22-2008 11:54 PM
Weak Power Supply ? 65 W Droid Hardware Support 4 03-04-2004 07:55 AM
