Old 11-19-2012, 02:42 PM
personalt's Avatar
personalt personalt is offline
HDHR Dying - Is HDHR Prime any differnt for OTA other then 3rd tuner
I have had a HDHR for a few years. I am starting to see issues when watching two shows at same time. I am starting to think it is an issue with the hdhr.
I was thinking about replacing it.. If I went with the prime(but only usa for OTA) are there any real changes I need to make to sage other then remove and add the new tuner.
Is it correct that I dont need any special plug-ins to use the Prime verision?
Old 11-19-2012, 03:01 PM
I don't believe the prime does over the air only cable card and QAM. If you are having problems with HDHR check the signal strength. I was having problems and the signal strength was showing low. Turns out all I needed to do was get a new power supply and everything was fine again.
Old 11-19-2012, 03:50 PM
Eckwell's Avatar
Eckwell Eckwell is offline
If you are having HDHR trouble check the power supply. Mine crapped out and was an easy swap to get it working again.
Eckwell / Chicago, IL
SERVER: AMD Phenom III 8750 Black / 4 GB / XP Pro / JV1.6.24 / V7 / 2 PVR-HD (DirectTV) & HDHR (2xATSC)
STORAGE: WD Raptor36GB boot / 11TB in 2 eSATA enclosure
DEFAULT STV
Comskip triggered by DirMON2 --- HD100 / HD200 /HD300
BMI fanart
HDHomeRun (HDHR) Prime + SageDCT svemuri Hardware Support 2139 01-26-2016 11:36 AM
Ceton & HDHR Prime scoful Hardware Support 12 01-21-2012 06:54 AM
HDHR Prime $169 @Newegg evilpenguin The SageTV Community 6 12-12-2011 08:42 AM
HDHR Prime / SageDCT / HDPVR BrianDC Hardware Support 1 11-30-2011 03:32 PM
HDHR Prime and Guide Data NetworkGuy Hardware Support 3 09-11-2011 07:45 AM
