Old 04-02-2003, 12:59 AM
edmc edmc is offline
Installer Suggestions
Not sure if the Installer makes sure that SageTV isn't running at the time, but that would be nice.
Installer always suggests the *default* install path. If it's a re-install, can't it get the previous install path from the Registry?
Finally, the Release Notes are apparently crafted in an editor with UNIX-style end-of-line conventions. If I bring up the file in a Browser or something like Visual Studio, fine. But if I simply view it with something like Notepad - well, of course, I get a very long 1-line file :-). I'd suggest a unix2dos be applied to the file meant to be viewed by PCers like us :-)
Old 04-02-2003, 11:19 AM
Narflex's Avatar
Narflex Narflex is offline
Sage
Hmmm, the installer should already do that. I'll look into it. I use the WISE Installer package so this is probably some option in there.
That's funny. I use notepad to write the release notes. The problem was with my FTP program; it was uploading in ASCII instead of BINARY for text files. I changed that and uploaded a new version.
Jeffrey Kardatzke
Google
Founder of SageTV
