Old 10-03-2011, 05:45 AM
Hunter69 Hunter69 is offline
Pheonix error please help
I can't seem to find posts in regards to the following error and its solution:
Error-Pheonix Error
Error in vfs file:.\stv\Pheonix\vfs\vfs.xml;Attribute "name" is required and must be specified for element typw "source".
The only post I could find similar to this is this one:
Pheonix error
I followed the instruction but cannot get rid of the above error.
I really appreciate any help.
Server: Antec 300, AMD Phenom 9750, 4 gig ram, 4 tb-with pooled recording , Lite on Blu-ray drive
Tuners: 2 HD-PVR, 1 HDHR
Clients: 2 HD200
Old 10-03-2011, 03:23 PM
Sounds like you have an old version of the xml file or xml validation file (dtd file).
Did you try to uninstall phoenix-core and re-install to see if the issue goes away?
Old 10-03-2011, 08:21 PM
I followed your instructions in the thread that I linked to, as soon as I reinstall I get the error. I did not get the error until the most recent upgrade.
Thanks for taking the time to help.
Clients: 2 HD200
Old 10-04-2011, 04:09 AM
Graygeek Graygeek is offline
+1
Old 10-04-2011, 09:50 AM
Given that vfs.xml has been removed from the packages, it seems odd, that after uninstalling and re-installing phoenix-core that you'd still get the error.
I'd remove the vfs.xml and restart the server. But, given that you are getting error it seems as though the plugin extraction process is failing to do the update, so it's hard to say what other issues you'll experience.
Old 10-04-2011, 10:18 PM
So can I just delete the file?
Thanks for your time
Clients: 2 HD200
Old 10-05-2011, 06:27 AM
I would, especially if you have an x-vfs.xml in there as well.
Old 10-05-2011, 09:18 AM
So are these the steps I should follow:
Stop the sage service.
Delete the file.
STart the sage service.
or should I
uninstall pheonix core
stop sage service
delete file
start sage
reinstall pheonix core
Clients: 2 HD200
Old 10-05-2011, 02:04 PM
Delete the file.
or should I
stop sage service
delete file
start sage
Both will work... but you don't even need to stop the service...
1. delete the file
2. in BMT web ui, refresh configurations
Old 10-05-2011, 06:08 PM
1. delete the file
Been on business travel, following this thread. Hope to try this over weekend after I get back. Been getting this error since last pheonix core update.
Thanks stuckless
Old 10-19-2011, 05:01 AM
Deleting the file did the trick! Thanks again Stuckless
Sagetv and Pheonix rnadeau Phoenix 0 09-23-2011 05:04 PM
Pheonix folder changed rickybee Batch Metadata Tools 2 07-31-2011 01:16 PM
Pheonix fanart file location TonyT SageTV v7 Customizations 14 04-19-2011 12:09 PM
6.4.5 doesn't install: error 1904 DLL registration error snipeman SageTV Beta Test Software 9 07-11-2008 02:31 PM
ERROR: sage.PlaybackException: Error (-4,0x8004022f): Boxpin SageTV Software 3 08-15-2006 08:23 PM
