Old 10-20-2020, 02:42 PM
PeteCress's Avatar
A Tale of Two HD-200's: one auto-reconnects, the other does not.
When I shut down the SageTV server and then start it up again:
  • One of my HD-200's doesn't miss a beat: it just seamlessly reconnects.
  • The other does not: I have to press the remote's On/Off button and pray. Mostly it reconnects, but sometimes it needs a cold start (cut off power and then re-apply power)
Frimware version on both = "20100909 0".
Maybe some local parm?
Program Source: OTA antenna
Old 10-20-2020, 06:07 PM
graywolf's Avatar
graywolf graywolf is offline
When in stand alone mode (before connecting), there is somewhere that you can tell it to auto reconnect and how many secs to wait. Think it is on the Server section, if not there, keep checking through the other areas.
A Tale of Two IPs... frontlinegeek SageTV HD Theater - Media Player 4 06-07-2011 12:55 PM
ver 7 auto compress is not auto compressing sfag SageTV Beta Test Software 2 04-20-2011 09:38 AM
auto program? woribhabor SageTV EPG Service 10 02-18-2011 03:32 PM
WHS Auto Rip ? Hunter69 Sage My Movies 1 10-15-2010 04:34 PM
My Gigabyte Bit Me - - A Tale of Woe Corey340 Hardware Support 7 11-14-2009 10:23 AM
