SageTV Linux Discussion related to the SageTV Media Center for Linux. Questions, issues, problems, suggestions, etc. relating to the SageTV Linux should be posted here. |
Sort of try before you buy
Hi,
I have a spare machine with XP pro license - unfortunately the installation disk is damaged. Rather than buying a new license which is about the only way to replace the disk in order to be able to start all over I wanted to give the linux version a try. I can understand the comment in the faq about the secure trial period - but as a somewhat experienced windows Sage user I know it works and what it looks like. What I don't know is whether the EPIA mainboard is supported. If I can install gentoo and play an mpeg with acceptable sound and video quality is it reasonable to assume that Sage will work as well? The machine is supposed to be used as a client. Jan |
Most likely, your EPIA will not be supported: the Linux version requires Geforce 4 MX or more recent NVIDIA graphic card.
It is often possible to acquire XP pro install disks (without licences) from Ebay, as well as other *cough* sources... As long as your licence is valid, it does not matter where you get your install media from. (But note that OEM licences don't work with retail install disks and vice versa).
Check out my enhancements for Sage in the Sage Customisations and Sageplugins Wiki ![]() |
Nielm,
thanks for the suggestion on the install disks - I'll disk doctor my install disk once more and then I'll make up my mind. I thought if I could get the distribution installed that would give an indication but it's probably easier to get matching hardware. Did some more reading and moving to another distribution seems to be a bit of a challenge. Moving Sage to a pre-installed Gentoo is probably not a lot easier. I saw somewhere that emerging the KDE took several hours so I don't want to think what that would be on the Epia. Also I still think that a trial makes sense not for what Sage looks like because that we already know but to verify the hardware you want to run on. Oh well, I can understand they don't want to go there given the reaction on the crippled MPV trial ![]() Jan |
Geforce 3 Ti200 works
If your installation CDrom is damaged call MS that if you really own it and they replace the disk for free. I'm sure there do a trial one someday but like all things build a crippled ver may not be as eazy as you think after all Linux is OpenSource. |
It's hardware decoding is excellent and you don't have to worry about speed. It's more expensive than a cheap PCI video card, but the results are worth it, really.... I got mine running 3 tuners in a Pentium III 500 with 376MB of RAM using an MVP. No real noticeable slowdown. It's actually really nice..... and much quieter than my P4. Lauren Lauren Last edited by laurenglenn; 02-15-2006 at 10:12 PM. |
