Old 04-05-2009, 06:55 AM
pedz25 pedz25 is offline
Getting the status after running an external command
I am using the built in functionality of the SageMC UI to run 2 external commands. One is a .cmd dos file to start the PlayOn service, the other file stops it. These both work great.
I am wondering if it is possible to display the status of PlayOn (started or stopped) as text on the same menu. I have a third cmd file that can report the status, but I don't know if I can display its output within SageMC.
Does SageMC have this functionality built in, or would it require some Studio work? If it does require Studio, can someone point me in the right direction? Maybe this type of thing has been done in other imports that I could use as examples?
Ed
external commands
External Command Tuner Plugin for Linux stuckless SageTV Linux 36 05-16-2017 03:11 PM
Plugin: External Status Monitor Interface (V1.3, 24-Jan-2006) nielm SageTV Customizations 150 03-25-2010 07:32 PM
Adding custom command for launching external program dinki SageMC Custom Interface 14 01-22-2010 08:16 AM
Dynamic Menus - How do I disable LIRC in Sage while running an external command? Norm258 SageTV Linux 0 02-14-2009 02:24 PM
Nielm's External Status Monitor - Download Link? swift_gti SageTV Customizations 2 07-10-2008 10:08 AM
