Old 02-06-2010, 11:14 AM
eyepulp eyepulp is offline
Sage can preview HD channels in setup, but not tune to them normally
We recently upgraded to the DirecTV H23-600 tuner and set up the new dish in order to get on the HD bandwagon.
Everything works fine on the receiving end, and we use a Hauppauge HD PVR to do the capture work.
HD channels are visible in my Video Source > Channel configuration, and I can successfully preview the HD channels in the Channel configuration area.
What doesn't work is tuning to those same HD channels via the program guide. I can get to my older SD channels, and even some of the new SD channels (yay for local programming coming back into my life). But when I select an HD channel, I see the IR blaster flash (as it should) and Sage takes the same amount of time it usually does, but then it ends up at the same channel I was on before attempting the change.
Is there something special about the HD channels I need to activate in Sage so it can tune to them? I though of running an s-video cable straight to the TV to watch the channel change attempt to see what the directv box was seeing from the IR, but that's about all I got...
Thanks for listening.
Last edited by eyepulp; 02-06-2010 at 11:16 AM. Reason: typing is apparently a challenge before my first Mt. Dew...
Old 02-06-2010, 07:55 PM
Lightbulb Problem solved, I'm touched in the head.
For anyone else with my malady - I had been adding the 2 digit version of the HD channels, instead of the replacement versions further along in the listings - HBO HD on channel 70, instead of the matched replacement for #501 HBO with #501 HBOHD. I can tune to the 3 digit version just fine.
So problems solved - though I can tune to SD 2 digit channels just fine, I'm not losing any more sleep over it.
Hope anyone else with the same problem has as simple of a solution.
channel change, directv, error, hd pvr
Channel Setup Preview works - Watch TV does not MalibuDave42 Hardware Support 4 10-06-2009 04:29 AM
Setup Wizard cannot see video preview psenechal SageTV Linux 11 04-09-2007 03:18 AM
PVR-150 no sound on a few channels (+ How to fine tune channels?) Evil Techie Hardware Support 12 12-08-2005 04:12 PM
How to tune channels FrankieTo SageTV Software 2 05-27-2004 09:51 PM
Please Help - Can't tune channels above 12 erics SageTV Software 12 03-02-2004 02:47 PM
