Old 02-14-2010, 08:29 AM
kchase56 kchase56 is offline
HD100 Firmware Update Problem
I've had no problems updating my firmware in the past, but when trying to update my current firmware (20090611 1) to the latest beta firmware, it is showing me the latest beta version (20100212 0), but when I try to update to it, using Firmware Update, I get the following error message =>
There was a problem downloading the firmware. Make sure you network connection is configured correctly. Contact SageTV...
I then downloaded the stx1000beta.bin file for 20100212 0 and tried the manual update/recovery procedure, but the procedure doesn't seem to work. I've enabled logging on my server and I don't see any references to stx1000.bin in it. Is the file supposed to be named stx1000.bin or stx100.bin? I've tried both and neither of them work.
Any information that you could provide regarding this problem would be greatly appreciated.
Old 03-07-2010, 10:05 AM
Anyone figure out a solution to this? I am getting the same problem on one of my HD100's that I finally decided to update today (updated a previous one with no problems about 3 weeks ago).
Old 03-07-2010, 07:38 PM
The solution that ultimately worked for me was to disable the SageTV service and just start the server before applying the firmware update. Hopefully this will work for you.
HD100: Aspect Ratio Messed Up After Beta Firmware Update hometheaterfan SageTV Beta Test Software 2 05-07-2009 09:36 PM
Can't update firmware lmeyer SageTV HD Theater - Media Player 2 01-02-2009 04:58 PM
HD100 Firmware update not working pvr599 SageTV Media Extender 4 05-24-2008 05:56 PM
Firmware Update eded9698 SageTV Media Extender 2 12-20-2007 09:37 PM
Firmware Update 92% hessjm SageTV Media Extender 28 12-13-2007 09:32 PM
