Plugin:: Serenity Theme for SageTV V7
This theme is available in the Themes area of the plugin manager.
Serenity V7 Version 1.0 is now available. See the second post for pics. Credits: Images for the backgrounds were found at www.htbackdrops.com Online background image courtesy of grooves12 Notes: 1) The install from the plugin manager installs the Theme, but doesn't select it. Eventually the plugin manager will prompt you if you want to install the new theme, but until then goto : Quote:
1a) If you are upgrading from a previous version of Serenity, you might have better luck if you select the default Theme before doing the upgrade. In either case you will need to reselect the Serenity V7 theme from the location noted above after you upgrade. 2) If you see any weirdness after selecting the theme, try restarting Sage to clear any cached images from old themes or the older version of Serenity. btl.
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient Last edited by bialio; 05-25-2010 at 01:29 PM. |
Pics for Version 1.0
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient Last edited by bialio; 05-25-2010 at 12:52 PM. |
Nice background images.
Very nice!
Thank you for all your work. Works great
12.04 server Sagetv7 HD-pvr / 2250 /PVR 500 / DVBS w/rotor & 36 inch dish |
This looks great! Thanks for all the work on this. Will be using it for sure.
Loaded up and looks great. Thanks
I have ?'s/ problems. When I hit the menu button on the remote it returns me to the SageMC menu. Is there a easy answer?
DRB
DRB I WANT MY HDTV |
OK, this is now fixed. I had to load the default STV and now all is good except for my HD-PVR.
DRB
v0.2 broke the theme. The notes say updated a few more button assets to serenity orange. Now I don't have any select cursor on my HD200 in the plug-in manager or detailed setup. There may be more areas, but didn't have time to navigate blindly to check it out.
This bring up my first problem with the plug-in manager, which is I have no way of returning to v0.1 right now and have to revert back to the default theme. ![]() |
You need to restart the Sage Service on your server. I reported this bug to Sage, but they didn't believe me. I'm glad you are having trouble - means I'm not crazy.
But a restart should clear it up - the cached images need to get flushed. Also make sure you re-apply Serenity (I'm assuming you already did) - the core doesn't do this automatically yet. btl.
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient |
I'd love a theme with just the different backgrounds and nothing else.
Clients: 1xHD200 Connected to 50" TH-50PZ750U Plasma Server : Shuttle SFF SSH55J2 w/ Win7 Home, SageTV v7, Core i3 540, 2GB RAM, 30GB SSD for OS, 1.5TB+2x1TB WDGP for Recordings, BluRay, 2xHDHR, 1xFirewire SageTV : PlayOn, SJQ, MediaShrink, Comskip, Jetty, Web Client, BMT Having a problem? Don't forget to include a log! (Instructions for: PlayOn For SageTV v1.5, MediaShrink) |
Thanks, restarting the service seemed to do the trick.
Bialio
for those of us who have managed to restrain from the v7 install (at least until lost is over) would it be possible to gt a few more screens for functionality, or is this just the backgrounds in the first post? |
It is just backgrounds and the highlighter is changed from grey to orange.
It's just backgrounds like PLUCKY said. A full on theme is coming, the main change is a move away from the PVC piping that the default UI uses as borders.
btl.
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient Last edited by bialio; 05-25-2010 at 01:35 PM. |
After installing the theme then switching back I noticed that the only other option for a default theme to switch back to was Standard SDTV theme. I am pretty sure it was set to a theme that said 1080p in it before switching to Serenity.
I don't know if it makes any difference or not as all my screens look fine with it. Also thanks for this theme, I just spent a couple of hours looking for background pics and came nowhere close to getting ones as nice as these. |
While the stock UI backgrounds are good, these are great! Thanks for putting these together!
My systems: Server: AMD Phenom Quad-Core 2.3Ghz, 4GB RAM, ECS A780GM-A MB, 2x HD-PVRs (connected to DirecTV HD STBs using ethernet channel changing), 1x AverMedia A180, OS RAID-1 mirror - 2x250GB 7200rpm SATA, Media RAID-1 mirror - 2x1TB 7200rpm SATA, USB-UIRT (remote control) Main Client: Sage STX-HD100 Media extender Second Client: Athlon XP 4000+, 2GB MB PC3200 DDR, Asus A8N5X MB, 512MB PCI-E ATI HD Radeon 3650, 160 GB SATA - hardware mirrored |
Serenity V7 1.0 is now available in the Plugin Manager. Enjoy! See the first and second post in this thread for updated info.
btl.
Plugin: MizookLCD (Alternate SageTV LCDSmartie Plugin) | cslatt | SageTV Customizations | 48 | 06-11-2012 10:44 AM |
STV Import: Serenity for SageMC | bialio | SageMC Custom Interface | 135 | 04-22-2010 11:36 AM |
Theme: Sage Pro UI theme for Standard STV 6.3 | gplasky | SageTV Customizations | 15 | 08-21-2009 11:57 AM |
Theme: Sage Pro MC Theme V0.08 for SageMC 16x9 STV V6.3.7 | gplasky | SageMC Custom Interface | 36 | 01-08-2009 11:40 AM |
Theme: Cogs UI Theme for Standard STV (V6.2 or later) | GKusnick | SageTV Customizations | 9 | 10-25-2007 04:39 PM |
