"Trailers" Suddenly Stopped Working
About a week ago the "Trailers" tab, when selected, says "loading trailers" and there is the little apple logo but it never loads the top trailers or lets one go further into the menu to look at/download other trailers.
Any thoughts? I am doing this on an HD200. I can back out of it, but going back into "Trailers" just gives the same effect - always loading, never loads. Would a totally "cold boot" of the extender help? My Sage Server is power cycled daily, and Sage Server is run as a program, not a service. I have not updated Java as it seems to be causing issues in other areas. Thanks for any help.
Asus P5Q Premium MB, E6750, 4GB RAM, 32-bit XP Pro SP3, 3Ware 9590SE controller, 80GB 7.2K Laptop boot drive w/SuperSpeed Cache Utility & eBoostr, (1) KWorld ATSC-110, (1) 950Q USB, (1) 2250 tuner, (1) HD-PVR using USB-UIRT, (1) 1600 Dual card, (1) DVICO Fusion 5 Gold, (1) Hauppauge 1250, (1) Hauppauge 2250, 8 various storage HD's, NEC-based x1 USB add-on card, 2 outdoor antennas capturing 2 different OTA markets, Dish Network w/HD Receiver for HD-PVR. |
I don't if this is related to what you're seeing but sometime last week, I noticed that two of the plugins that Ortus Trailers needed wouldn't update properly Ortus Core and Ortus MQ I think. So I uninstalled the Trailers plugin, then those two Ortus ones, then reinstalled the Trailers plugin and everything was back to normal again.
You might want to check the General tab of your installed plugins and see what's up with the Ortus plugins...
HD-PVR w/v1.5.6 drivers / Hauppauge IR blaster / FiOS Extreme HD / Motorola QIP6200 / SPDIF+720p Fixed Output on HP Media Center 8400F (Phenom 9500 QuadCore 2.2GHz, nVidia GeForce 8500 GT) via Olevia 247TFHD/Onyko TX-SR606/Harmony 550/HP MediaSmart EX490 WHS w/12TB Plex Media Server v0.9.9.5 on HP Touchsmart Envy 23 d16qd Sonos Play:3, Connect / SimpleTV v2 / Roku 2 XS+Plex / iPhone 5 / iPad 2 |
I've had this happen twice (one of the times this past weekend), and both times it was due to disk problems. I run sagetv under WHS V1. I've had a disk go missing with bad sectors and the disk has trailers on them. Once the disk problems are corrected the trailer plugin was fine.
Just a thought .... dave
HDTV's - Pioneer Elite Pro 150FD - Plazma - Sharp 37D62 - LCD - Sony 40 in LCD 1 x HD200 - connected to 150FD 1 x Sage TV server Pioneer VSX92THX receiver Monitor one 5.1 surround speakers Sony S550 Blueray |
Thank you both for the great ideas. I'll start with the software ideas and work towards the mechanical possibilites.
I know if I go without my trailers tab too long I will begin to develop abandonment issues... Thanks again.
BTW, last week it just started working fine again.
No clue what went wrong for that period of time. Thanks again for the suggestions and such.
"Metadata In Info List" - "Off" Not Working? | darcilicious | Diamond | 1 | 03-07-2011 02:19 PM |
"SageTv has stopped working" | Jesse | SageTV Software | 4 | 11-24-2010 08:03 AM |
Suddenly "No Signal" after years of no problems | robinson | SageTV Software | 3 | 08-27-2007 07:24 AM |
Vista error "SageTV has stopped working" | cnafl | SageTV Software | 0 | 01-28-2007 02:59 PM |
2.1.9/10 Problem - SageTV Recordings List Suddenly Empty ... moved to "Archived" ??? | sudipto | SageTV Software | 3 | 11-04-2004 03:08 AM |
