Go Back   SageTV Community > SageTV Development and Customizations > SageTV v7 Customizations > Gemstone for v7
Gemstone for v7 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 12-19-2012, 11:30 AM
Sort By Recent Activity Vs Sort by Original
One if the sorts I really miss from the Default STV Is to be able to sort group titles by Original air date descending. This truly gives me the most recent airings... as opposed to Recent by Activity which gives me reruns or anything recently recorded at the top.
I tried sorting the groups by Original airdate but all it does is sort by alpha title. This works great using the default STV.
Old 12-19-2012, 11:50 AM
jusjoken jusjoken is offline
Can you provide a little more info around the settings you are using... which View are you using, and what Presentation Groupings/Sorts are you trying to use.
k
Old 12-19-2012, 12:02 PM
k
I am using the Sage Flow. Grouped by Title sort by Recent Activity sort order descending.... that gives me the most recent recordings even reruns at the top that works as expected.
If I change the sort to Original Airdate descending .. all it does is sort by title in reverse order.
In the default STV it puts the group with the most recent original air date at the top. This comes in handy when people in my household record a lot of reruns they are pushed to the bottom of my list.
Old 12-19-2012, 03:02 PM
Which of the TV views are you using? Look in the options in the flow next to View:
k
Old 12-19-2012, 03:24 PM
Recorded TV
Screen Attached as you can see it sorts it title reverse order.
The Default STV works fine.
Old 12-19-2012, 06:40 PM
I checked with Stuckless as the Group/Sort functions are all from the phoenix core and the solution you are looking for is the Sort By "Recent Activity" rather than Original Air Date... it uses OAD but has been specifically coded to handle the sorting of the main group.
k
Old 12-19-2012, 08:03 PM
k
Ok Recent Activity does not do what I want so I will use the default for that View sort on OAD. Recent Activity does not appear to sort on OAD in group it simply sorts on date recorded. So it put reruns above first runs if the rerun is recently recorded not what the default does on OAD.
Thanks ... I thought I was doing something wrong.
Old 12-20-2012, 08:04 AM
That is correct... The Recent Activity sorter, while smart enough to look into child folders, does sort based on the recorded time.
The Original Air Date Sorter, while sorting on the original air date, is not smart enough to look into sub folders when folders are in the list.
Personally, I think the original air date folder should look into sub folders, and might end up changing that sorter to do this at some point.
Old 12-24-2012, 03:17 AM
OferL OferL is offline
I would join the op and ask for the same. Whenever you could...
Old 12-24-2012, 04:54 PM
mdnttoker mdnttoker is offline
yo tambien
Old 04-03-2013, 11:53 AM
Any news on this ... this is the main reason why I stopped using Gemstone.
SateTV 7 sort Folder entries by Original Air Date? joe123 SageTV Software 2 11-30-2010 10:12 PM
Feature Request: Sort by Original Air Date rerooks SageTV Software 6 10-15-2009 04:35 PM
Sort MediaFile List by Most Recent First? MeInMaui SageTV Studio 2 09-06-2008 02:47 PM
Sort series by original air date? eobiont SageTV Customizations 2 07-07-2007 05:45 AM
Sort of try before you buy jhh SageTV Linux 6 02-15-2006 10:26 PM
