Old 10-07-2005, 03:31 PM
jlabrue jlabrue is offline
Encoder merit gui
Are the any STV's out there or plugins that will allow you to set the encoder merit on multiple tuner systems without editing the sage.properties file? It would be cool if it was just built into the default STV where you configure the tuner in the source setup gui. This could also be included on the screen everyone wants that allows you to rename each of your encoders to something that makes sense to you rather than the default name "Hauppauge WinTVPVR..." that is so descriptive
I know this can be done with the properties file but it would be very convenient to add what is probably fairly simple functionality to the Sage gui. An import to the default STV for something like that would rock! I know which one I want to change from within Sage but it is difficult to figure out which of the 5 tuners I have correspond to the Sage device. Does Cayers on one of the others allow this? May not be high on many priority lists but just wanted to check if something was already out there that I am missing.
Sage.....feature request.....
Old 10-07-2005, 03:54 PM
It isn't worth the time for anyone to develop such a system of setting the encoder merit inside the UI, because those values are currently only checked at startup time. Been there, done that.
Old 10-07-2005, 08:03 PM
insomniac's Avatar
insomniac insomniac is offline
awe... i like that option!
If you're not cheating, your not trying...
My sage rigs:
Server - Windows 2003, Intel 865 PERLL w/ P4 3.2g 1gb ram, 3-PVR250, 3-PVRUSB's, 1 Skystar2, 1 twinhan 102g, 1 starbox DVB-S Cards. Evo network QAM encoder. 1.2TB storage 6.x server + MTSAGE for DVB
Client 1/Master BR - MediaMVP running a 30" Olevia LCD TV.
Client 2/Front Room - Shuttle ST61G4 XPC 1gig ram, 60gb HD, BTC9019 wireless keyboard/mouse & Harmony 880. 6.x client. GF6600GT driving a Sony WEGA 55" rear projection tv.
