Go Back   SageTV Community > SageTV International User Forums > SageTV Australia/New Zealand
SageTV Australia/New Zealand SageTV and SageTV Recorder Users from the Land Down Under - This forum is for you to post about specific issues using SageTV software in Australia and New Zealand.
Old 02-10-2007, 11:17 PM
wilsonj wilsonj is offline
So what importer are most using?
OK, I got things running, eventually. But I am having some strange problems with the STV importer by Stephane.
What importer are most Aussies using?
And what xml grabber are you using? Python/oztivo??
Cheers
Jamie
Old 02-11-2007, 03:26 AM
ozfiles ozfiles is offline
Hi Jamie,
I'm using Demideus xmltv plugin http://forums.sagetv.com/forums/show...ighlight=xmltv it's very configurable and hasn't let me down yet.
I have included my config files to give you an idea of the layout. I have optus cable so get the fta channels, as well as the pay tv channels on the decoder, so I just down load one xml file called pay.xml from oztivo and then using a batch file copy and rename it to fta.xml and move both files to the sage directory.
I did try Stephane's importer but I had trouble with running version 5 of java, it tended to close sage intermittently. Running version 6 now, with none of the I had with version 5.
There is a grabber for oztivo now, which makes things easy, so you might like to give that a try.
regards,
oz
File Type: zip xmltv config.zip (602 Bytes, 370 views)
Old 02-12-2007, 02:34 PM
Hi Oz,
Thanks for your reply and files.
I have finally got StephaneM's importer working. Weird problem was it wouldn't read my epg.xml file in the directory it was in. Once I moved it everything worked!!! No one can answer why!!
Finally got everything working right, as far as the guide goes.
I now have video issues, but I will start a new thread on that one.
Thanks for your help
Cheers
Jamie
Old 02-15-2007, 05:34 AM
mickp's Avatar
mickp mickp is offline
Welcome to sage
Hey wilsonj,
I remember seeing you about on the ss forums. Welcome to sage.
I'm using Stephane's plugin (as I did in btv) with an icetv subscription.
Mick.
