Old 09-28-2007, 01:13 PM
lovingHDTV's Avatar
Controlling encoder merit via STV
I'm wondering how hard it would be to list the video sources according to their encoder merit? Additionally adding the ability to change their merit similarly to favorites, where you could click on the encoder, then move it up or down to change its merit.
I think this would be a nice enhancement, but is it practical?
thanks,
dave
Old 09-28-2007, 02:32 PM
Yes, the merit property could be modified in an STV & the default STV even has unused code from a time when I played around with it. But, it won't take effect anyway until the server is restarted, meaning you have to restart the service or the UI if not using service mode. So, someone could do that as long as you know you have to restart.
Old 09-28-2007, 10:00 PM
jlabrue jlabrue is offline
I think this feature would be really cool to have. I struggle identifying which tuner I am actually looking at when trying to set priority (I have 2 PVR-500s so it shows 4 tuners that look the same in the properties file). It would be great just to be able to do that graphically even though I would have to restart everything.
Is this something that could be enabled/disabled in the properties file like the Malore menus or could it just be the default and have a little help box informing the user to restart everything after making the change?
Old 09-28-2007, 10:35 PM
You mean the unused STV code I mentioned? It is just that: unusable in the UI.
Anyway, I spoke too soon above. I took a minute to see if I ever even finished the code (I only did it to play with some API calls a long time ago when I hadn't done a lot of STV editing yet)... and I'm going to take back what I said above: It looks like you can't do this in an STV w/o some sort of core change (unless I missed an API call) because when you exit SageTV, the merit property values are reset to what they were when SageTV started.
Old 09-29-2007, 01:28 AM
GKusnick's Avatar
GKusnick GKusnick is offline
Not quite the same. Look for lines line this:
mmc/encoders/12345678/video_capture_device_name=Hauppauge WinTV PVR PCI II Capture
mmc/encoders/12345678/video_capture_device_num=1
The device_num + 1 tells you which device this is in the UI. So in this example, device_num=1 means this device will show up in the UI as Hauppauge WinTV PVR PCI II Capture #2.
-- Greg
Old 09-29-2007, 04:42 PM
That is good to know. I was unaware that that setting existed or what it was for. Since Opus said it couldn't be done anyway this makes my life easier and eliminates me from needing anything. Thanks Greg. Sometimes something so simple is right in front of you.
Old 09-29-2007, 04:45 PM
Sorry, I didn't differentiate between unused and unusable but yes, unused code. Was just wondering if it could be fleshed out to become usable code but looks like you answered that already. Thanks Andy.
Simple (but effective) security for any STV Lester Jacobs SageTV Customizations 5 12-17-2010 03:21 PM
STV Import: Change Encoder Display name in Parallel Recording Schedule BobPhoenix SageTV Customizations 10 12-31-2009 03:17 PM
Channel Line up and Encoder Merit akenis SageTV Software 4 05-28-2007 01:51 PM
Encoder Merit not enforced Muchacho SageTV Beta Test Software 22 11-24-2006 01:48 PM
