Old 06-20-2011, 01:45 PM
pjwerdna pjwerdna is offline
HD300 hangs for 30 seconds on startup
Hi
Anyone else seem an HD300 hang for 30 seconds on the "Loading..." screen?
Wll think thats what its shows, its the progress bar before it gives you chance to abort connection to the default server.
Thought at first it was an issue with the server, but there's nothing in the logs (sageTV or event log) and rebooting has made no differnce.
It doesnt seem to effect normal running, just the startup. Both from power saving mode and powered off.
Been having the trouble since saturday I think so it may or may not be the missing sage website!
SageTV Server : Akasa Inifiiti Case, Gigabyte GA-P35C-DS3 MB, 8600GT, Core2 Duo (E6850 3GHz), 4GB RAM, ~6TB Filestore , Nova-TD500, TBS 6280, SageTV 7.1.9
New Client 2 :MSI P67A-GD53, i5 2500K Quad core (3.3GHz), 12GB, Windows 10 Pro (and test SageTV 9 Install)
Sage Client 1 : HD300, Logitech Harmony One
Service startup hangs on system startup Sparhawk6 SageTV Software 6 04-08-2010 08:35 PM
HD200 hangs on startup rswoods SageTV Media Extender 12 12-12-2008 02:10 AM
Service hangs at startup soulprops77 SageTV Software 4 01-27-2007 09:10 AM
SageTV hangs on startup dpalmer95 SageTV Software 5 01-01-2007 02:58 PM
client hangs on startup jsturtevant SageTV Software 1 08-31-2004 09:29 AM
