Old 11-28-2011, 08:02 PM
infocus13's Avatar
infocus13 infocus13 is offline
Question Help! Get seasons & episode data from filename??
Hi guys
I have a fairly simple problem, which seems to be very difficult to solve! Hoping someone can help me out.
1. I'm running SageTV + Phoenix + BMT. Latest versions for everything.
2. I live in Australia & grab my EPG data from OzTivo and use LM Gestion's importer to get it into SageTV.
3. It appears that OzTivo includes the Season & Episode info in the show title. So my shows are title as follows: "TheBigBangTheory-Season3Episode10TheGorillaExperiment-13916457-0.mpg"
4. I have verified the above using BMT - season & episode fields are left blank and the show title is "Season 3 - Episode 10 - The Gorilla Experiment"
So my problem is simple. How do I parse the season & episode info from the title into the season & episode fields in SageTV/BMT to enable accurate grouping by season?
So far I've tried:
1. Renaming files to the format "showTitle-s01e01-episodeTitle.mpg". I don't like this approach & would like to avoid using it.
2. MediaTitles.xml - as far as I can tell there is no way to accomplish the above using XML?
3. Changing the way SageTV names its recordings - cant do it as far as I can tell.
Is there anything I can do at all?
Thanks for your help in advance.
Old 11-28-2011, 08:55 PM
stuckless stuckless is online now
Originally Posted by infocus13 View Post
Hi guys
So far I've tried:
BMT uses "scrapers" to scrape the filenames. They are basically an mix of xml and regular expressions. I've provided a handful of the most common scraper formats, but, I don't have a scraper for the format that you have -provided.
If you feel confident, you can try your hand at creating a scraper... they are located in the STVs/Phoenix/scrapers/xbmc/tvfilenames/ directory.
Old 11-28-2011, 08:57 PM
infocus13's Avatar
Thanks Stuckless. Two questions:
1. What is the best way to learn how to write a scraper? I've mastered VFS so I can learn this as well, but what is a good guide? The BMT manual?
2. How do I "activate" a scraper once I have written one? Is that in the user guide? What is the naming convention for the file, etc?
Cheers
Old 11-28-2011, 09:06 PM
I haven't tested this, but the following scraper should work, or at least be a good starting point.
<?xml version="1.0" encoding="UTF-8"?>
   TV Filename Scraper.  Used to Scrape Show Name, Season and Episode from a given file URI
   $$1 is always the complete file uri
<scraper name="title-Season00Episode00" content="filename" thumb="thumb.png">
	<!-- 	input: 		$1=complete file uri -->
	<!-- 	returns: 	show name -->
	<GetShowName dest="3">
		<RegExp input="$$1" output="\1" dest="3">
			<expression>.*[/\\](.*)-Season([0-9]+)Episode([[0-9]+)</expression>
		</RegExp>
	</GetShowName>
	<!-- 	returns: 	Season #-->
	<GetSeason dest="3">
		<RegExp input="$$1" output="\2" dest="3">
		</RegExp>
	</GetSeason>
	<!-- 	returns: 	Disc #-->
	<GetEpisode dest="3">
		<RegExp input="$$1" output="\3" dest="3">
		</RegExp>
	</GetEpisode>
</scraper>
Old 11-28-2011, 09:10 PM
infocus13's Avatar
You rock. Will try this out tonight.
Thanks.
Old 11-28-2011, 09:15 PM
infocus13's Avatar
Actually, one more question stuckless....
Reading the userguide again, you have the following scraper already defined:
"Series S##E##
This is used to match TV shows in the format “SeriesName S##E##.ext”
Examples
House s01e01.avi
House - S01E01 - Episode Title.avi
Lie to Me s02e03.avi
Lie to Me - s01e01 - Pilot Episode.avi"
My files are named almost as per the second example (bolded) above. So if I just go in & amend that scraper to change "S" to "Season" and "E" to "Episode" - would that work??
Old 11-29-2011, 12:16 PM
It should work... (I say should, becuase I'm not 100% sure)
Old 12-05-2011, 02:28 AM
infocus13's Avatar
Ok, we're getting there...
The scraper in your other post did not work. However, I did manage to change the season & episode format to "S01E01".
So now my filenames look like this:
TheBigBangTheory-S2E09TheWhiteAsparagusTriangulation-13920147-0.mpg
However, the default scraper included with BMT (Title-s00e00.xml) does not seem to work... I still don't get any season or episode details populated into BMT when the file is in the new format. S/E fields are blank.
Any ideas on what am I doing wrong?
Thanks.
Old 07-25-2017, 02:02 PM
Oatz Oatz is offline
This may be a dead thread, but if you are still looking for this, there is an option in:
Sage/Setup/Detailed Setup/Customize"
"Include Season and Episode Numbers in Filenames"
Turn this on and optionally make sure
"Include Episode Names in Filenames"
Is also turned on!
Win!
Capture Server: Sage 9 - i7 16gb 256gb SSD Windows 10 32bit
3 x Colossus with 3 Rogers HD STBs - Firewire Blasting via FWproxy, EXE Tuner
NAS: Win 7 - Dual Xeon, 48gb, 9TB Raid 6 Array w/ Comskip running in DirMon
Clients: HD300
Have hardware like mine and need help? Just PM me
How do you like to rip bluray tv seasons? medwynd Sage My Movies 38 05-10-2011 09:59 AM
TV View seperates some seasons? jusjoken Batch Metadata Tools 1 11-11-2010 06:38 PM
Season/Episode in filename svalmorri SageMC Custom Interface 6 09-24-2009 09:42 PM
More than 9 seasons? bigo93bronco SageTV Software 2 09-23-2009 08:17 PM
Episode data - recording error; need suggestions Surtr SageTV Software 7 07-30-2008 01:58 AM
