Old 11-29-2011, 12:28 PM
jusjoken jusjoken is offline
Diamond 3.32 - Weather Icons - Day/Night fix +
We have issued a small update for Diamond that will now use the original SageTV weather icons as well as taking into account the time of day to show Night based icons where appropriate.
This change includes using these icons for the NWS extended forecast for those able to use NWS.
You can also configure the Day Start and End time (defaults to 7am/7pm) in the Weather Options screen.
We also included a fix for the 0 Watched count in TV Recordings in the Diamond Info view.
If you run into any instance where you still see a Google or NWS icon please let us know so we can add a match to display the appropriate image.
k
Old 11-30-2011, 11:47 AM
Polypro Polypro is offline
Looks awesome JJ, thanks for the continuing support!
p
Old 11-30-2011, 12:37 PM
les_bloom les_bloom is offline
Thank you for the update
Old 12-12-2011, 02:22 PM
saltlyck2 saltlyck2 is offline
idea
Wonder if the current moon phase could be incorporated.
Just wget a pic like this - overlay clouds or whatever with irfanview.
http://cdnimg.visualizeus.com/thumbs...c2bfea2c_h.jpg
Old 12-18-2011, 06:56 PM
WIcons update for Diamond users
Version 1.003 of the WIcons API
- added missing icon for NWS
- NWS Forecasts now use the night icons for night forecasts
As Diamond 3.32+ uses the WIcons API please update the WIcons API in the plugin manager if you want the changes noted above.
k
Old 01-04-2012, 09:21 AM
nateziemann nateziemann is offline
Updating from 3.30 to 3.32 on my client turns off all fanart in the Diamond Fanart settings panel. It will not allow me to change from off to on. Nor can I set my fanart location for the client. Both options are disabled. The upgrade worked great on my server. I've attempted to reinstall the diamond client plugin, no luck ... Any thoughts on resolving?
Old 01-04-2012, 10:27 AM
There were no changes to any of the Diamond code other than the few calls that display the icons and widget related weather display so I doubt this is directly releated to the version (and other users have not reported an issue). so I have to assume something in your properties or install of the STVi went wrong. If you have already tried an uninstall then install of the plugin then try a clearing of the Diamond settings (see Wiki) to see if that resolves it.
k
Old 07-03-2012, 10:01 AM
Version 1.004 of the WIcons API
- added some missing icons for NWS
- fix to support NWS Forecasts change to using png icons
k
Old 07-12-2012, 08:27 AM
Looks good. I almost missed this...figured it would show up as an update in Sage. Had to figure out I had to go into the Library section and then saw 'Update Available'. Nice job, the weather screen looks a whole lot better now...those square default graphics were horrible.
P
Old 07-13-2012, 12:37 PM
P
We have posted an update so users will be reminded to update this plugin to support the minor change in the Weather Icons for NWS Forecasts..
k
Old 07-14-2012, 10:05 AM
mkanet's Avatar
mkanet mkanet is offline
I got the update this morning. Since the download was going a bit slow even on my 120mbit connection for a second there I thought... could this be THE big update? Then quickly realized the version number did say 4.00. Anyway, I am very grateful for the continued support! Keep up the good work.
***RIP SageTV***
Plugin: WIcons - enables Day/Night Weather Icons for default SageTV STV jusjoken SageTV v7 Customizations 28 10-17-2015 02:37 PM
Weather Icons saltlyck2 SageTV Customizations 3 06-05-2006 11:51 AM
Weather Icons DIBU SageTV Customizations 0 02-27-2005 08:14 AM
Weather Icons spike5884 SageTV Customizations 7 07-31-2004 03:05 AM
