Go Back   SageTV Community > SageTV Development and Customizations > SageTV v7 Customizations > Gemstone for v7
Gemstone for v7 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 06-11-2016, 09:34 AM
RBraverman's Avatar
RBraverman RBraverman is offline
I'm not seeing what everyone else is ...
... granted I am new to this; SageTV and especially Gemstone. AND I promised that I would not bother anyone this weekend, but then of course there is the woman I live with, but I digress ...
This post: http://forums.sagetv.com/forums/show...65&postcount=8
Details how to do what I want, an option to show folders that are on my recording drive so that I can see my recordings within folders, with metadata.
But as I try to follow the instructions, I'm not seeing almost all of what jusjoken has written.
I don't see where to start in relation to explaining this, but when he instructs:
"Type: Dual Flow
View: Base - All Videos:"
I'm not seeing or do not know how to get to: Gemstone Views, where it starts listing views and has a section "Base Views (to build from), the attached is what I see.
AND I am getting errors regarding the vfs-cached.xml; null
AGAIN MANY THANKS!
Signed:
Your Friendly (really, I am), annoying pain-in-the-a**.
Sorry Fuzzy, I know I said I would leave ya all alone.
PS: I JUST discovered the conversion ... GREAT, now it's easier to deal with playing on my Tablet. I'm liking this more and more.
Core2Duo 3.0, 8gig Memory, Win7 x86, LOTS O' Storage tucked into an Antec Case. OLD aTI Remote Wonder.
Sage V9.0.13.536
Java V1.8.0_121 (8.11)
Base STV V7.1.9.12
JettyWebServer V2.3.0.14
Phoenix Core V 3.0.4
Old 06-11-2016, 10:25 AM
KryptoNyte's Avatar
Are you manually moving your SageTV show recordings into directories other than the recording directory itself?
Old 06-11-2016, 12:10 PM
RBraverman's Avatar
Yes, and it works. But more importantly I'm missing a whole section of Gemstone, that is seriously curtainly my ability to set this up. I've un-installed it, re-installed it, to no avail.
Sage V9.0.13.536
Base STV V7.1.9.12
Old 06-11-2016, 01:08 PM
KryptoNyte's Avatar
Some of my archived media is sorted in directories, per show. A quick FYI, this isn't the way SageTV is necessarily meant to work, I just like it this way. Gemstone has since allowed for this kind of sorting inside the SageTV UI, showing all your shows in their respective 'folders' so to speak, yet with all the media stored in just one recording folder.
In my case, I have the root directory of this archived media mapped in SageTV as an import folder. So from the [Gemstone] default main menu;
I navigate to VIDEOS, and then select FOLDERS, and it then displays all of my archive sub-folders. There is probably a way to further clean this up, but it works very well for my situation.
What variation from the above example were you hoping to achieve?
Old 06-11-2016, 01:53 PM
RBraverman's Avatar
Pretty much the same thing - as long as the metadata is with the files. BUT I'm missing the entire views options from within Gemstone and without them not only is the thing incomplete, but I can not define the rest of my "flow".
Sage V9.0.13.536
Base STV V7.1.9.12
Old 06-11-2016, 02:51 PM
jorton jorton is offline
If you are not seeing any Gemstone views you may be missing the phoenix vfs file. I recently had to reinstall using V9 and Gemstone and had to follow these instructions to get the views to show.
See this post.
Old 06-11-2016, 03:24 PM
RBraverman's Avatar
See this post.
MAN you saved my sanity! You're Aces. I would have NEVER found that, and WAS about to start clean over.
I'd have had a monster amount of work as 400+ were imported from BTV.
WHEW!
Any idea, as a LAST bit, how t have it search for missing poster/fanart/artwork? And is there some sort of notification when converting, and/or when the conversion's done?
Sage V9.0.13.536
Base STV V7.1.9.12
Old 06-11-2016, 04:27 PM
I think you just have to make sure that you have named your movies and tv shows in a format that BMT can scrape for you.
I usually name the TV shows with SxxExx in the name and for movies I use the IMDB name with the year in brackets. For example,
Friends S01E01.mkv
Zootopia (2016).mkv
I have also used stuckless' Phoenix Renamer here to clean up names.
I can't recall how BTV (used a very long time ago) names the files...
Hope this helps.
Old 06-13-2016, 02:29 AM
WHEW!
Man, I'm pretty sure I already pointed you to that issue and the fix in the other thread.
Old 06-13-2016, 07:48 AM
RBraverman's Avatar
Just looked through all the posts and it's not there, but then again I had everyone bouncing all over the place.
Sage V9.0.13.536
Base STV V7.1.9.12
Old 06-13-2016, 08:59 AM
post 32 in your EPG thread. http://forums.sagetv.com/forums/show...7&postcount=32
Old 06-14-2016, 08:04 AM
RBraverman's Avatar
Sorry (BTW I wasn't trying to be an a**hole about it, if it came off that way) - that WILL teach me to start paying attention - the time I spent ...
Why isn't that part of the install? Or did I miss that too?
Sage V9.0.13.536
Base STV V7.1.9.12
Old 06-14-2016, 08:26 AM
I wasn't upset - just didn't point you immediately towards that when you started having issues setting up gemstone because I had assumed you had already fixed that part.
I believe the vfs file was done as a separate download because there were some conflicts between the Phoenix Core for the default and gemstone STV's, and the Full Phoenix UI. Packaging the same file in both plugins caused problems, so it will instead just download that file if it isn't there - the problem is it was hosted on google code, so when that shut down, it couldn't find it. A new version of the Phoenix Core needs to be released to fix where it downloads from, but that hasn't happened yet (this is really a relatively new problem based on google code actually shutting down downloads quite recently). Existing users don't see the problem (because they've already got the file), only on new installs (of which there have not been a lot).
Old 06-14-2016, 03:21 PM
RBraverman's Avatar
Actually as I remember, I hadn't even loaded Gemstone, as I was trying to get to know my way around before I complicated things.
Makes sense.
I'm opening another thread on the way the guide looks. Doesn't belong here.
AGAIN thank you for all the help.
Sage V9.0.13.536
Base STV V7.1.9.12
