Old 09-23-2016, 02:42 PM
CollegeProject CollegeProject is offline
Questions on show images
Are the GetShowImage or GetShowImageCount suppose to return anything? The only way I can get images for shows is using GetSeriesImage. Just curious if these are suppose to return anything? I am on version 9 with a valid license for guide data. I tried all the calls like "PosterTall" etc as well as a 0 on image count and they all return 0.
This is for shows in the guide not recorded or local yet if that matters.
thanks
SCP
Old 09-26-2016, 08:30 AM
I think availability is pretty limited. In most cases, there is no image provided for an individual episode, in which case Sage typically generated a thumbnail from a set timestamp into the program.
Old 10-27-2016, 08:44 AM
So to further this, there is really no way to get an image series or otherwise for allot (around 60% in my case) of livetv current airings? I find it odd this calls are there and they are empty.. I am guessing the provider Google used provided these images where as the SageTV provider doesnt?
Old 10-27-2016, 08:54 AM
EnterNoEscape's Avatar
Generally you will only get a thumbnail for movies. For episodes, you will mostly only get thumbnails from the associated SeriesInfo object if one exists for the series associated with the episodes. This was my observation on WarlockRipper when I was implementing the Schedules Direct support into the core. My understanding is that things are done this way to keep the size of the database objects down. Schedules Direct does provide episode photos, but they are vertical for some reason which really looks weird when it's literally a frame from a widescreens show, so I opted to not have them at all in my core implementation.
Old 10-27-2016, 09:09 AM
Phoenix Fanart apis also provide episode specific fanart... But not sure it's used anywhere. I'l l likely be testing this out in the next few days myself.
Old 10-27-2016, 09:54 AM
Ya I don't use schedules direct addon but I see the same I get some series images but very few unfortunately.
Is this for unrecorded tv (ie livetv) care to share that call? I use the episode specific fanart for stuff that is scrapped already no issues using phoenix.fanart.GetEpisode() and phoenix.fanart.GetDefaultEpisode() but those don't scrap on demand correct? I am looking for a way to get stuff from the guide airings which are not recorded or already scraped.
Old 10-27-2016, 01:45 PM
If the LiveTV is tuned, you should be able to use...
MediaFileAPI.GenerateThumbnail(MediaFile, seconds, w, h, outFile);
Phoenix uses this in it's VideoThumbAPI to generate video strips from a file. The catch of course is that the MediaFile must be a real file (ie, currently recording, or previously recorded)
Old 10-28-2016, 09:38 AM
bialio's Avatar
bialio bialio is offline
I don't think we ever got video strips working for currently recording files. I seem to remember that it was just on the complete files for some reason...
PHOENIX 3 is here!
Why does Sage Playback show two video images side by side? galtigor123 SageTV Software 2 07-06-2012 06:42 AM
How do I get images to show for my dvd's??? rdefino SageTV v7 Customizations 7 02-23-2011 07:35 AM
How do get images to show for DVDs rdefino SageTV v7 Customizations 14 11-02-2010 02:49 PM
Is there any way to show program images from XMLTV? ehanekla SageTV EPG Service 0 05-26-2008 09:23 AM
Questions about Show Analyser and Comskip pddurke SageTV Software 2 05-08-2006 02:10 PM
