Old 11-18-2016, 09:33 AM
CollegeProject CollegeProject is offline
Circularities
Anyone know why studio keeps throwing some of my stuff down into circularities is that normal? I am creating loops like (hard to write studio code.
i=0
if-i<num
true
  if- variable true
         true
             do this
         else
             i=i+1
             revert to if-i<num
Old 11-18-2016, 10:28 AM
Of note it still works but I have a feeling something is off with how I am doing it. Or maybe it's normal for it to be thrown in circularities?
Old 11-18-2016, 10:52 AM
are you asking if there is a better way to do this? or are you having a problem doing this? question isn't all that clear.
Old 11-18-2016, 11:20 AM
I am asking if it's normal for it to be thrown in circularities section of the STV on reimport.
I searched an found a couple of threads and it seems normal although odd.
Old 11-18-2016, 11:56 AM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
I suppose technically it's a probably a bug in the way studio identifies the Primary Reference in a loop. Before any work in Studio, I just set the top widget of the offending loop as a Primary Reference and the Circularities disappear.
John
Old 11-18-2016, 01:11 PM
John
Ya I noticed that but they reappear on import again it's odd but I'll ignore it thank you!
Old 11-18-2016, 01:50 PM
tmiranda's Avatar
tmiranda tmiranda is offline
John
+1. It's just the way Studio works.
Old 11-18-2016, 01:57 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
This generally shouldn't happen. IIRC, stuff should only show up in circularities if there is a set of Widgets that are all connected together via some parent-child relationship...and none of those Widgets have no parents (and also are not a Menu). These Widgets should essentially be unreachable from any other code. If this isn't what you are seeing...feel free to open an Issue on GitHub and put an example STV in there for me to look at.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 11-18-2016, 04:11 PM
JREkiwi's Avatar
I'll create an issue with example
John
Circularities, sometimes..... tmiranda SageTV Studio 2 04-09-2016 03:15 PM
Circularities dflachbart SageTV Studio 3 02-16-2006 08:47 PM
